Simpliying this partial differential equation
In summary, simplifying a partial differential equation involves reducing its complexity by applying mathematical techniques such as variable separation, transformation methods, or dimensional analysis. These methods aim to find solutions more easily or to express the equation in a more manageable form, ultimately facilitating analysis and computation.
Safinaz
261
How to simplify this partial differential equation?
Hello, I need help in this simple example:
Consider for instance a partial differential equation:
(x + y ) \delta_{ij} + \partial_i \partial_j x = \partial_i \partial_j y + z \delta_{ij} , ##
where ## \delta_{ij} = (-1,1,1,1) ## is a diagonal metric, and ##x ## , ##y ##, and ##z ## are functions in ##i,j## .
Does this equation mean that:
## x+y =z ##, and
## x = y##?
I mean ## \delta_{ij} ## terms in the LHS of the eqaution equal those at the RHS ?
with knowing that ## \partial_i \partial_j x ## term dose not vanish for ## \delta_{ij}=1 ##
Any help is appreciated!
I think your notation is confusing. Can you clarify:
  • What range does the index ##i## run over: ##\left( 1,2,3\right)## or ##\left( 0,1,2,3\right)## or something else?
  • What explicitly are the variables ##w^i## that you are differentiating with respect to, i.e., ##\partial_{i}=\partial/\partial w^{i}##?
  • How are these variables related to ##x,y,z##?
Hi, thanks for reply.
  • What range does the index ##i## run over: ##\left( 1,2,3\right)## or ##\left( 0,1,2,3\right)## or something else? Ans.: ##\left( 0,1,2,3\right)##
  • What explicitly are the variables ##w^i## that you are differentiating with respect to, i.e., ##\partial_{i}=\partial/\partial w^{i}##? Ans.: It is ##\partial_{i}=\partial/\partial w^{i}##?
  • How are these variables related to ##x,y,z##? Ans.: consider for instance ##\partial_{i} x =\partial x /\partial w^{i} ##. So that x, y and z can be written explicitly as x(w), y(w), and z(w).
OK, thanks for clearing things up!
So we have:$$\left(x+y\right)\delta_{ij}+\frac{\partial^{2}x}{\partial w^{i}\partial w^{j}}=\frac{\partial^{2}y}{\partial w^{i}\partial w^{j}}+z\delta_{ij}\;\Rightarrow\;\left(x+y-z\right)\delta_{ij}=\frac{\partial^{2}\left(y-x\right)}{\partial w^{i}\partial w^{j}}$$or:$$U\delta_{ij}=\frac{\partial^{2}V}{\partial w^{i}\partial w^{j}}\quad\text{where}\quad U\equiv x+y-z,\;V\equiv y-x\tag{1a,b,c}$$Contracting (1a) with ##\delta^{ij}## gives ##4U=\partial^{2}V/\partial w^{i}\partial w_{i}\equiv\square V##, leading to:$$\frac{1}{4}\square V\delta_{ij}=\frac{\partial^{2}V}{\partial w^{i}\partial w^{j}},\quad U=\frac{1}{4}\square V\tag{2a,b}$$The off-diagonal (##i\neq j##) terms of (2a) are: $$0=\partial_{0}\partial_{1}V=\partial_{0}\partial_{2}V=\partial_{0}\partial_{3}V=\partial_{1}\partial_{2}V=\partial_{1}\partial_{3}V=\partial_{2}\partial_{3}V$$with the unique solution ##V=k##, where ##k## is an arbitrary constant. Thus, ##U=\frac{1}{4}\square V=0##, and from (1b,c) we get finally:$$y=x+k,\;z=2x+k\;\left( x\text{ an arbitrary function},\;k\text{ an arbitrary constant}\right)$$
Likes Safinaz
Thanks so much for the answer : )
FAQ: Simpliying this partial differential equation
What is the general approach to simplifying a partial differential equation (PDE)?
The general approach to simplifying a PDE involves identifying symmetries, applying coordinate transformations, using separation of variables, and reducing the number of independent variables. Techniques such as Fourier transforms, Laplace transforms, and similarity solutions are also commonly employed to simplify the equation.
How can separation of variables be used to simplify a PDE?
Separation of variables is a method where the PDE is rewritten as a product of functions, each depending on a single coordinate. By substituting this product into the PDE, the equation can often be separated into simpler ordinary differential equations (ODEs) that can be solved independently.
What role do boundary and initial conditions play in simplifying a PDE?
Boundary and initial conditions are crucial in simplifying a PDE as they provide specific constraints that can reduce the complexity of the solution. They can help determine the constants of integration and can sometimes allow for the use of special functions or series expansions to solve the PDE more easily.
How can symmetry methods help in simplifying a PDE?
Symmetry methods involve identifying invariances under certain transformations, such as rotations, translations, or scaling. These symmetries can be used to reduce the number of variables or to transform the PDE into a simpler form. Group theory and Lie algebras are often used to find and exploit these symmetries.
What are some common transformations used to simplify PDEs?
Common transformations used to simplify PDEs include Fourier transforms, Laplace transforms, and similarity transformations. These transformations convert the PDE into an algebraic equation or an ODE, which is typically easier to solve. For example, the Fourier transform is particularly useful for solving linear PDEs with constant coefficients.
