FrankJ777
- 140
- 6
I'm need to simulate a circuit with a FST3126 4x bus switch in Multisim. I was planning on using the component wizard to make an FST3126 as it's not one of there components, but I'm not sure how it works. Looking at the data sheet logic diagram I though the component acted like 4 switched inputs on the A side to outputs on the B side. I assumed that the switches were closed by asserting a high on OE1-4, and that closing the switch would essentially create a "short" from the A side to the B side. Reading another post though, it indicated that the outputs of the FST3126 could only be between 0V to VCC. So this would not seem like simple switched, but maybe FETs?? I'm not sure what the logic diagram is supposed to indicate. I'm hoping someone can enlighten me. I've attached part of the data sheet, and you can find the full datasheet here: http://http://www.fairchildsemi.com/ds/FS/FST3126.pdf
Thanks
Thanks
