svletana
- 21
- 1
Hello! I'm trying to simulate a one dimensional time independent BEC, I hope this is the right place to ask for help.
First of all, here's my code in Python.
It's not very complex up to this point. What my program does is start the simulation with some random wavefunction. I calculate the density and build the Gross-Pitaevskii Equation (GPE) and solve by calculating eigenvalues and eigenstates. Afterwards, I normalize the eigenstates and start over by taking the new eigenstate, calculating its density and solving the GPE once again (I'm working only with the ground state). It's a fixed point iteration.
I'm hoping that after a good number of iterations, the wavefunction will look like a Gaussian, which should be the ground state for a 1D BEC.
However, if you run the program you will find the wavefunction doesn't seem to converge to any particular waveform. The chemical potential values also don't match what I predict (around 0.5ω for a small number of particles, where ω is the trapping potential's frequency, and the theoretical value for the TF approximation for a large number of particles).
Also, I don't see how the particle number is involved in this equation other than in the g coefficient. How is that supposed to change my result aside from a different effective potential?
I'll gladly take any other suggestion or advice! Thanks in advance! :)
Python:
import sys
import numpy as np
import matplotlib.pyplot as plt
if len(sys.argv) == 1:
niter = 100
elif len(sys.argv) == 2:
niter = int(sys.argv[1]) # number of iterations
else:
print('Please insert only the iteration number')
exit(1)
# useful functions
# Laplacian operator for the second derivative
def Laplacian(x):
h = x[1]-x[0] # assume uniformly spaced points
n = len(x)
M = -2 * np.diag([1]*n)
for i in range(1,n):
M[i,i-1] = 1
M[i-1,i] = 1
return M/h ** 2# for normalizing eigenstates
def Normalizate(U, x):
h = x[1] - x[0] # assume uniformly spaced points
n = len(x)
for j in range(0, n):
suma = 0.0
for i in range(1, n):
suma = suma + U[i, j]**2
suma = suma * h
rnorm = 1 / np.sqrt(suma)
# print j,’ integral (sin normalizar) =’,rnorm
# Normalization
rsign = 1
if U[1, j] < 0:
rsign = -1
rnorm = rnorm * rsign
for i in range(0, n):
U[i, j] = U[i, j] * rnorm
# parameters for Rubidium 87 (a.u.)
m = 87 # mass
a = 110 # scattering length
N = 500 # particle number
g = 4 * np.pi * a * N / m # coefficient for gross pitaevskii equation
w = 1 # frequancy of trapping potential
L = 1.5
dx = 600
# initialize wavefunction
x = np.linspace(-L, L, dx)
phi = [20 * np.exp(- (i ** 2)) for i in x]
W = 0.5 * m * (w ** 2) * (x ** 2)
# main loop
for i in range(niter):
# calculate density
density = [abs(p * p) for p in phi]
# schrodinger's eq in matrix form
T = -0.5 / m * Laplacian(x) # kinetic energy
P = g * np.diag(density) #GPE non linear term
H = T + np.diag(W) + P #hamiltonian
E, U = np.linalg.eigh(H) #eigenvalues and eigenstates
Normalizate(U, x)
phi = U[:, 0]print('chemical potential: ' + str(E[0]))
### Theorical value for the chemical potential, only works for the Thomas Fermi approximation!
ff = (3*g*N*np.sqrt(m/2)*w)**(2/3)
print('theoretical value (TF): ' + str(ff))
# plt.plot(x,W,'--k')
plt.plot(x,U[:, 0])
plt.show()
