Simulating Inertia of a Vehicle
In summary, the brake inertia dynamometer needs to simulate both momentum and kinetic energy. The braking forces are determined by the momentum and the energy absorbed is determined by the kinetic energy. There is not enough information given to solve this, so we need to make some assumptions.
Oli166
Hi all
I am in the process of designing a brake inertia dynamometer to test one complete corner of a car's braking system.
I'm having some trouble with what size the spinning disc of metal, that will simulate the energy of the moving car, needs to be. I have the inertia value that I need to simulate (roughly 2000 kgm/s)
I also have a formula to calculate the moment of inertia for a cylinder but i have a feeling that these are two different things.
So any help with how I can calculate the size and mass of the disc and also how I would calculate the speed it needs to be rotated at.
Cheers
Oli
ping @jrmichler. Can you help with this spring cleaning thread?
A brake dynameter needs to simulate both momentum and kinetic energy. The braking forces are determined by the momentum and the energy absorbed is determined by the kinetic energy. There is not enough information given to solve this, so we need to make some assumptions.
Assume a small car that weighs only 1000 kg, so the quarter car model is 250 kg. If the momentum (not inertia) of the quarter car model is 2000 kg-m/s, then the velocity is 8 m/s, or just under 18 MPH. The kinetic energy is 8000 joules.
Next, we need to assume a tire diameter, so randomly pick a 155/80R13, which is 0.584 meters diameter (dimension from tirerack.com). At 8 m/sec, the tire is rotating 4.36 revolutions per second, or 27.4 rad/sec.
Next, simplify by assuming direct drive from flywheel to brake (no gear reducer). We need a flywheel that has 8000 joules kinetic energy at 4.36 rev/sec (262 RPM, 27.4 rad/sec). Since the kinetic energy of the flywheel is ##I\omega^2##, and you have both the kinetic energy and speed (27.4 rad/sec), you can solve for I. Then use the equation for inertia of a cylinder to pick the diameter and length of your flywheel. This is trial and error because the length determines the diameter (or the diameter determines the length), so you choose a combination of length and diameter that work for your system.
There are several ways to drive the flywheel. You can mount it directly on the output shaft of a gear reducer, you can run a V-belt around the OD of the flywheel, and there are many other ways. Note that the inertia of the motor driving the flywheel is part of the inertia of the flywheel, and that the motor inertia is reflected to the flywheel by the square of the gear (or drive) ratio.
Likes anorlunda
Related to Simulating Inertia of a Vehicle
1. What is inertia and how does it affect a vehicle?
Inertia is the tendency of an object to resist a change in its motion. In the case of a vehicle, it refers to the resistance of the vehicle to changes in its speed or direction. This is important because it determines how the vehicle responds to external forces, such as acceleration, braking, and turning.
2. How is inertia simulated in a vehicle?
Inertia can be simulated in a vehicle using mathematical equations and computer simulations. These simulations take into account factors such as the mass of the vehicle, its velocity, and the forces acting on it to accurately model its movement.
3. What are the key factors that affect inertia in a vehicle?
The key factors that affect inertia in a vehicle include its mass, velocity, and the distribution of its mass. A heavier vehicle will have more inertia, while a vehicle with a higher velocity will have more kinetic energy and thus be more resistant to changes in its motion.
4. How does inertia play a role in vehicle safety?
Inertia plays a crucial role in vehicle safety by influencing how the vehicle responds to sudden changes in its motion. For example, a vehicle with high inertia will take longer to stop when braking, which can affect its ability to avoid collisions. Understanding and simulating inertia is important in designing and testing vehicles for safety.
5. How do you measure and quantify the inertia of a vehicle?
The inertia of a vehicle can be quantified by calculating its moment of inertia, which takes into account the mass, shape, and distribution of the vehicle's mass. This value is typically measured in units of kg*m^2. In practical applications, computer simulations can also be used to estimate the inertia of a vehicle.
  • Classical Physics
  • Mechanical Engineering
  • General Engineering
