Simulating noise with Yuler and Burg
The problem is that the generated sequences tend to diverge and produce large values, which may not be normal. Kalman filter can be used to estimate the error in the sequences, rather than directly integrating the values from the simulation. This may be a better approach for managing the noise in the sequences. In summary, the conversation discusses the use of functions in python to analyze recorded data and generate sequences using an auto-regressive model with white noise. However, there may be an issue with the generated sequences diverging and producing large values. It is suggested to use a Kalman filter to estimate the error instead of directly integrating the values from the simulation.
ramesses
Hi
After removing high frequency white noise in my INS sensor, I want to simulate low frequency noise with Burg or Yuler.
I used some functions in python to analyse the recorded data and to get parameters to use.
But the the problem is the sequences generated diverge (and take very big values), is that normal ?
I use the following equation :
XN+4=XN+3*C3+XN+2*C2+XN+1*C1+W1
where W1 is white noise.
I have another question.
Why I have to use kalman filter to estimate the error ?
Why not to integrate directly the value given by the simulation ?
I have no idea what you wrote. Is that English? :bow:
It seems to be some sort of auto-regressive model, but I don't recognize the math. Perhaps if that were clearer (use that little Σ button if it helps) more people would respond.
Also another forum might find more people familiar with this sort of math.
English is my 3rd language :wink:
XN3i=0Xi*Ci +W1
Related to Simulating noise with Yuler and Burg
1. What is the purpose of simulating noise with Yuler and Burg?
The purpose of simulating noise with Yuler and Burg is to create a model of random fluctuations or disturbances that occur in real-world data. This can help researchers better understand and analyze the effects of noise on their data.
2. How do Yuler and Burg methods simulate noise?
Yuler and Burg methods simulate noise by generating a random sequence of numbers using statistical techniques. These numbers are then added to the original data to create a noisy version of the data.
3. What is the difference between Yuler and Burg methods?
The main difference between Yuler and Burg methods is the way they estimate the parameters of the random sequence of numbers. Yuler method uses a linear prediction model, while Burg method uses a more sophisticated autoregressive model.
4. Can Yuler and Burg methods be used for any type of data?
Yes, Yuler and Burg methods can be used for any type of data as long as the data follows a stationary process, meaning that its statistical properties do not change over time.
5. How can simulating noise with Yuler and Burg help in data analysis?
Simulating noise with Yuler and Burg can help in data analysis by allowing researchers to test the robustness of their data analysis methods against different levels of noise. It can also help in identifying the impact of noise on the results and in developing strategies to minimize its effects.
