Simulating the E-field distribution using the charge distribution
In summary, charge distribution is useful when simulating electric field intensity because it allows for more accurate results than electrostatics.
willDavidson
50
TL;DR Summary
How do I simulate e-field using charge distribution?
Hello everyone,
I am new to this site so I hope this is the right place to ask this. I understand simulating electric field intensity using electrostatics because E=V/d makes sense to me. I do not understand how to consider e-field intensity using charge distribution. When is charge distribution useful compared to electrostatics? I apologize in advance if I'm not even using the correct terminology.
Thank you in advance,
Will
What you are asking is the heart of electrostatics. The controlling equation relates the divergence of the Electric field to a given charge distribution. The relationship runs both directions.
For some geometries ("infinite" flat sheets and spheres for instance) simple relations can be derived.
If charges are allowed to move and circulate, the entire power of Maxwell's equations must be used, as well as the notion of Magnetic fields...
If charges are allowed to move and circulate like the charge in two wires with current flowing through both?
I've seen some papers stating that they used a voltage to define a boundary condition for simulation. I think others used charge? If I have two conductors separated by some distance, why would I apply a charge to them and not a voltage?
The relationship between charge and voltage is capacitance. C = Q / V.
willDavidson said:
Summary:: How do I simulate e-field using charge distribution?
Hello everyone,
Will
If you are given an arbitrary charge distribution ρ(x,y,z), you can solve for the potential φ by solving Poisson's equation [itex] \nabla^2 \varphi = -\rho/\epsilon_0 [/itex] . Once you have φ, you can solve for E given E = -∇φ. There are many ways to solve Poisson's equation, some analytic, and some numeric. But the point is, if you know ρ everywhere, you can solve for E everywhere. This assumes things are static. If the charges are moving, then it gets more complicated. But the bottom line is the same. If you know the charges and currents everywhere, you can solve for E and B everywhere.
I'm still trying to understand why the charge wouldn't be uniform in a conductor. Is this like if a conductor has a higher current density near a cutout or something and there's a much higher current density? If so I guess that would mean the E-field intensity would be higher there as well? I'm trying to understand a practical application of this method.
Consider two nearby conductors, at different potentials.
The electron density on the surface will change due to electrostatic forces.
https://en.wikipedia.org/wiki/Electrostatic_induction
Likes willDavidson
Related to Simulating the E-field distribution using the charge distribution
1. What is the purpose of simulating the E-field distribution using the charge distribution?
The purpose of simulating the E-field distribution using the charge distribution is to understand and predict the behavior of electric fields in a given system. This can help in designing and optimizing devices and systems that rely on electric fields, such as electronic circuits and antennas.
2. How is the charge distribution used in the simulation of E-field distribution?
The charge distribution is used as an input parameter in the simulation of E-field distribution. By specifying the distribution of charges in a system, the simulation can calculate the resulting electric field at different points in space.
3. What factors affect the accuracy of the simulation?
The accuracy of the simulation depends on several factors, including the complexity of the charge distribution, the resolution of the simulation grid, and the accuracy of the mathematical model used to calculate the electric field. Additionally, the simulation may be affected by external factors such as boundary conditions and material properties.
4. Can the simulation of E-field distribution be used for practical applications?
Yes, the simulation of E-field distribution has many practical applications, such as in the design of electronic devices, analysis of electromagnetic interference, and optimization of wireless communication systems. It can also be used in scientific research to study the behavior of electric fields in different systems.
5. Are there any limitations to simulating the E-field distribution using the charge distribution?
Yes, there are some limitations to this type of simulation. For example, the simulation may not accurately capture the effects of material properties and boundary conditions, and it may not be able to account for dynamic changes in the charge distribution. Additionally, the accuracy of the simulation may be limited by the computational resources available.
  • Electrical Engineering
