MHB *Simultaneous equation 4 variables
  • Thread starter Thread starter karush
    Variables
The discussion focuses on solving a system of equations for variables x and y in terms of parameters a and b, under the condition that ab ≠ -1. The derived solutions are x = (a + 1) / (ab + 1) and y = a(b + 1) / (ab + 1). Participants explore different methods for solving the equations, including substitution and Cramer's rule, highlighting the equivalence of denominators. The use of determinants in Cramer's rule is noted as a more systematic approach, making it easier to verify results. Overall, the thread emphasizes various techniques for solving simultaneous equations effectively.
karush
MHB
Solve the following system for x and y in terms of a and b where $ab\ne - 1$
$\left\{{\frac{x+y-1}{x-y+1}=a
\atop\frac{y-x+1}{x-y+1}=ab}\right.$
Answer is
$x=\frac{a+1}{ab+1}\\y=\frac{a\left(b+1\right)}{\left(ab+1\right)}$
I tried for a hour and?
Noticed the denominators were = but?
Mathematics news on Phys.org
Answer is
From the first equation
x + y - 1 = a(x - y + 1)
or
(1 - a)x + (a + 1)y = a + 1
From the second equation:
y - x + 1 = ab(x - y + 1)
or
-(ab + 1)x + (ab + 1)y = ab - 1
If you don't want to match coefficients or use substitution you could always do it using Cramer's rule:
[math]\left ( \begin{matrix} 1 - a & a + 1 \\ -(ab + 1) & ab + 1 \end{matrix} \right ) ~ \left ( \begin{matrix} x \\ y \end{matrix} \right ) = \left ( \begin{matrix} a + 1 \\ ab - 1 \end{matrix} \right )[/math]
So
[math]x = \frac{ \left | \begin{matrix} a + 1 & a + 1 \\ ab - 1 & ab + 1 \end{matrix} \right | }{ \left | \begin{matrix} 1 - a & a + 1 \\ -(ab + 1) & ab + 1 \end{matrix} \right | }[/math]
and
[math]y = \frac{ \left | \begin{matrix} 1 - a & a + 1 \\ -(ab + 1) & ab - 1 \end{matrix} \right | }{ \left | \begin{matrix} 1 - a & a + 1 \\ -(ab + 1) & ab + 1 \end{matrix} \right | }[/math]
It might look bad, but it's more "mechanized" than the other two ways, and easier to check.
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
