Simultaneous equation involving cos, sin
In summary, simultaneous equations involving cosine and sine often require solving for multiple variables that are interrelated through trigonometric identities. These equations can be addressed using substitution methods or graphical representations, and solutions typically involve finding angles that satisfy both equations simultaneously. Techniques such as the use of identities (like the Pythagorean identity) and transformations can simplify the process, leading to solutions for angular relationships in various applications, such as physics and engineering.
atky1224
i was solving a engineering four-bar linkage problem until this part and I'm stuck.
I was trying to find out θ3 and θ4 by using the vector loop method and i got the following equations:
50cosθ3 - 45cosθ4 = 39.67
50sinθ3 - 45sinθ4 = 32.58
is there any lead as to how to solve for the values of θ3 and θ4?
considered using sin^2 θ + cos^2 θ = 1 but not sure if i am on the right path.
Thanks a lot in advance!
I assume there is a typo somewhere since the left sides of your equations are the same and the right ones are not. If you are only interested in the solutions then you could use https://www.wolframalpha.com/. If you want to solve it manually, then what are the revised equations?
oh yes, sorry, there is indeed a typo on the second equation, it should be [50sinθ3 - 45sinθ4 = 32.58]. i wanted to solve it manually, but my attempt was stuck at trying to put everything at the right side and leave θ3 on the left side from the first equation, thus making θ3 = arccos[(39.67+45cosθ4)/50]. then i tried substitute θ3 into the second equation and stuck there with my poor mathematic brain...
\begin{align*}
50\cos \theta_3-45 \cos \theta_4&=39.67 \\
50\sin\theta_3-45\cos\theta_4&=32.58 \quad \text{ times }(-1)\\
\hline \\
-50\sin\theta_3+45\cos\theta_4&=-32.58 \quad \text{ add }\\
\hline \\
50\cos \theta_3-50\sin\theta_3&=7.09 \quad \text{ divide by }50\\
\cos \theta_3-\sin\theta_3&=0.1418
\end{align*}
... which yields ...
https://www.wolframalpha.com/input?i=cos+x+-+sin+x+=+0.1418
or
https://www.wolframalpha.com/input?i=cos+x+-+sin+x+=+0.1418+and+0<x<1
... and you can plug in the result to obtain ##\theta_4.##
Likes atky1224
This is ##\theta_3 = 0.6849616481889901703151683129191662012375748774207522750296488810\ldots ## and in degrees of 360° it's ##\theta_3= 39,24541157°.## Thus
\theta_4=\cos^{-1}\left(\dfrac{50\cos 39,24541157° - 39.67}{45}\right) \approx 91,207°
Likes atky1224
ohh now i see how it is going. please allow me to digest the whole thing. thanks a lot for the guidance
fresh_42 said:
\begin{align*}
\hline \\
\hline \\
\end{align*}
For information, I think the second equation is incorrect and should be:
##50\sin\theta_3 - 45\sin\theta_4 = 32.58##
Likes nasu
fresh_42 said:
Because you have written ##\cos\theta_4## instead of ##\sin\theta_4##.
Oops!
That ...
\begin{align*}
50\cdot \cos \theta_3 - 45\cdot \cos \theta_4 &= 39.67 \\
50\cdot \sin \theta_3 - 45\cdot \sin\theta_4 &= 32.58
\end{align*}
... makes it more complicated and non-linear as the image on WA ...
https://www.wolframalpha.com/input?i=50*cos(a)+-+45*cos(b)+=+39.67+AND+50*sin(a)+-+45*sin(b)+=+32.58
... shows. In this case there is no other way (that I knew of) than using the numerical algorithmic solution.
The angles on WA are in RAD, so multiply them with ##\dfrac{360}{2\pi}## if you want normal degrees ##(\cdot)°##
Likes DrClaude
Relevant Equations: considered using sin^2 θ + cos^2 θ = 1 but not sure if i am on the right path.
Here’s an outline possible method.
You have 2 equations of the form:
##a\cos A - b\cos B = p## and
##a\sin A - b\sin B = q##
where ##A## and ##B## are unknown angles and ##a, b, p## and ##q## are known constants.
Eliminate one of the angles, e.g. eliminate ##A## as follows:
##a\cos A = p + b \cos B##
##a\sin A = q + b \sin B##
Square both of these equations and add them. Use '##\sin^2+\cos^2 = 1##'.
With a bit of algebra you get:
##a^2= p^2 + q^2 + b^2 + 2b(p\cos B + q\sin B)##
For neatness let ##k = \frac {a^2 -p^2 - q^2 -b^2}{2b}## giving ##p\cos B + q\sin B = k## which can be solved.
Likes nasu and phyzguy
atky1224 said:
Homework Statement: i was solving a engineering four-bar linkage problem until this part and I'm stuck.
It looks like these equations correspond to the vector equation ##\vec A - \vec B = \vec C## where ##\vec A = (50, \theta_3)##, ##\vec B = (45,\theta_4)##, and ##\vec C = (C, \theta_C)##, where ##C=\sqrt{39.67^2+32.58^2}## and ##\theta_C = \arctan 32.58/39.67##.
You can isolate each vector and then square the resulting equation to get
\begin{align*}
A^2 &= B^2 + C^2 - 2BC\cos(\theta_4-\theta_C) \\
B^2 &= A^2 + C^2 + 2AC\cos(\theta_3-\theta_C) \\
C^2 &= A^2 + B^2 + 2AB\cos(\theta_3-\theta_4)
\end{align*} It's the same thing Steve did above if you note that ##p=C \cos\theta_C## and ##q=C\sin\theta_C## except you avoid some algebra.
FAQ: Simultaneous equation involving cos, sin
What is a simultaneous equation involving sine and cosine?
A simultaneous equation involving sine and cosine is a set of equations where at least one equation contains the sine function and another contains the cosine function. These equations can be solved together to find the values of the variables that satisfy both equations.
How do you solve simultaneous equations involving sine and cosine?
To solve simultaneous equations involving sine and cosine, you can use substitution or elimination methods. First, isolate one variable in one equation and substitute it into the other equation. Alternatively, you can square both sides of the equations to eliminate the sine and cosine functions, leading to polynomial equations that can be solved using algebraic methods.
Can you provide an example of a simultaneous equation with sine and cosine?
Sure! An example of a simultaneous equation is: 1) sin(x) + cos(x) = 1 2) sin(x) - cos(x) = 0. To solve these, you can manipulate the equations to express one variable in terms of the other and find the values of x that satisfy both equations.
What are the common methods for simplifying simultaneous equations involving trigonometric functions?
Common methods for simplifying simultaneous equations involving trigonometric functions include using trigonometric identities (like Pythagorean identities), converting all functions to sine or cosine, and factoring. These techniques can help to reduce the complexity of the equations, making them easier to solve.
Are there any specific applications for solving simultaneous equations involving sine and cosine?
Yes, simultaneous equations involving sine and cosine are often used in physics and engineering, particularly in problems related to oscillations, waves, and harmonic motion. They can also be applied in signal processing, electrical engineering, and other fields that involve periodic functions.
