Single chart which covers entire [itex]S^1\times R[/itex] manifold
  • Thread starter Thread starter Ravi Mohan
    Manifold
The discussion centers on the concept of charts in manifolds, particularly regarding the manifold \( S^1 \times \mathbb{R} \). It highlights the confusion around whether a single chart can cover the entire manifold, with participants clarifying that while \( S^1 \) cannot be covered by one chart due to its topology, \( S^1 \times \mathbb{R} \) can be homeomorphic to an open subset of \( \mathbb{R}^2 \). The conversation also touches on the definitions of open sets and the nature of subsets in topology, emphasizing that a manifold is open in itself. Participants discuss the implications of contractibility on covering manifolds with charts, concluding that non-contractible manifolds can still be covered by a single chart under certain conditions. Overall, the thread explores the nuances of topology and chart definitions in the context of general relativity.
  • #31
PeterDonis said:
Only if the range of ##\theta## is at least half-closed, i.e., it needs to include ##\theta = 0## or ##\theta = 2 \pi##. But a chart is supposed to map open intervals to open intervals. If the range of ##\theta## is the open interval ##(0, 2 \pi)##, then the image is missing an entire ray in the ##x, y## plane, from the origin to infinity along the positive ##x## direction.
The region S(A,B) on a cylinder with A < z < B and 0 \leq \theta \leq 2 \pi is an open set. To see this, note that it is the union of two open sets:
  1. S_1(A,B) is the set of all points (z,\theta) with A < z < B and 0 < \theta < \pi
  2. S_2(A,B) is the set of all points (z,\theta) with A < z < B and \frac{\pi}{2} < \theta < \frac{5 \pi}{2}
By definition of open, a union of two (or even countably many) open sets is another open set. If we take countably many such open sets, we get another open set:
S(0,\infty) = S(0, 1) \cup S(\frac{1}{2}, 2) \cup S(\frac{3}{2}, 3) \cup ...
Also, if the chart has to map open intervals to open intervals, the domain of the chart is not all of ##S^1##; it must be missing at least one point (the one corresponding to ##\theta = 0## and/or ##\theta = 2 \pi##). I always understood that this was the primary reason why closed manifolds could not be covered by a single chart.
The entire S^1 is an open interval, since it is the union of the interval 0 < \theta < \pi and \frac{\pi}{2} < \theta < \frac{5 \pi}{2}.
So it's a weird fact that S^1 cannot be covered by a single chart, but S^1 \times R can be.
Likes vanhees71 and atyy
  • #32
If ##\theta## was a member of the real line ##\mathbb{R}##, your objection would be valid. But it's not, it's a member of ##S^1##, "real numbers mod 2##\pi##", so "##\theta = 0##" and "##\theta = 2 \pi##" are two descriptions of the same point in ##S^1##, and of the same point in ##\mathbb{R}^2## under stevendaryl's mapping (for a given ##z##).
  • #33
I think you're repeating some of the misconceptions you had on a previous thread here. For example, the reason that ##\mathbb{S}^1## cannot be covered by a single chart is not that it is a 'closed' manifold (All manifolds are closed).
  • #34
Ravi Mohan said:
I am studying Carroll's notes on GR. He defines charts as maps from an open subset in manifold M to open subset in R^n. He then writes
"We therefore see the necessity of charts and atlases: many manifolds cannot be covered with a single coordinate system. (Although some can, even ones with nontrivial topology. Can you think of a single good coordinate system that covers the cylinder, S1 × R?)"
So when we have defined the chart as a map whose domain is an open subset in the manifold then how can a single chart cover the entire manifold? Or am I missing something?
S1xR is homeomorphic to an open subset of R2. Just take R2 minus the origin. So it is a manifold that can be covered by a single chart and is topologically nontrivial - by which I suppose you mean it is not contractible.
S2xR is homeomorphic to an open subset of R3.
Likes atyy
  • #35
Thanks for explaining that. Now regarding my second question
Ravi Mohan said:
when we define the homeomorphism from an open set of the manifold to ##\mathbb{R}^n##, do we assume the topology of ##\mathbb{R}^n## to be usual topology?
  • #36
yes. whenever one says Rn one means the usual topology.
  • #37
Ok that is great. I think I have got the answers to my satisfaction here.
  • #38
Ah, got it.
  • #39
Not sure what previous thread you're referring to (possibly you have confused me with another poster?), but see my response to DrGreg.
Doesn't a closed manifold have to be compact? Not all manifolds are compact.
  • #40
PeterDonis said:
Doesn't a closed manifold have to be compact? .
Yes. And it doesn't have a boundary.
  • #42
a closed manifold can not be covered by a single chart since no open subset of Rn is compact, So the circle can not be covered by a single chart - nor can a sphere or a doughnut.
- a manifold might not be closed even as a metric space, for instance Rn minus a point.
  • #43
- a manifold my not be closed even as a metric space.
Which is exctly why i asked in which sense he means closed this time, because last time i saw he used it in a very different (wrong) way. With this of course i agree that the sphere cannot be covered by one chart since homeos preserve compactness as all continuous maps do.
  • #44
Cruz Martinez said:
In which sense do you mean closed?
In the sense of a closed manifold. In the previous thread you linked to, it was pointed out (and I agreed once it was pointed out) that, topologically speaking, the entire space is always closed. But "closed" in the sense of a closed manifold is something more specific: a compact manifold without boundary. Not all manifolds meet that definition. And, as you appear to agree, such a manifold cannot be covered by a single chart. Which was what I said about ##S^1## earlier.
By the same definition, ##S^1 \times R## is not a closed manifold (it's not compact), so it can be covered by a single chart, as stevendaryl showed (and after his and DrGreg's correction, I see how that works, as I posted before).
  • #45
You said that every manifold is closed. But whatever definition of closed you choose this is not true. The plane minus a point is not closed as a metric space and is not a closed manifold.
  • #46
A manifold that is not closed may still not be coverable with a single chart. An example is a torus minus a point.
  • #47
I meant closed in the sense of 'a closed subset of its own topology' which is the sense in which peter tried to use the term last time. It is certainly true for any manifold that it is a closed subset of its own topology! I tried to interpret what peter said this time and i was simply wrong in that interpretation. This doesn't meant i don't know a closed manifold is compact without boundary, and i will leave it at that.
  • · Replies 25 ·
  • · Replies 51 ·
  • · Replies 17 ·
9K
  • · Replies 83 ·
  • · Replies 17 ·
