Single Degree-of-Freedom Systems
  • Thread starter aminbpy
  • Tags
    Systems
In summary, To find the natural frequency of the SDOF system, with mass 20 kg and spring constant 350 N/m, an initial displacement of 10 mm and initial velocity of 100 mm/s are given. The natural frequency is 0.666 Hz and the period of vibration is 1.502 sec. The amplitude of vibration is 25.91 mm and the time at which the third maximum peak occurs is 3.285 sec. To find the amplitude of vibration and time for the third maximum peak, the total energy of the system can be calculated using the equation ##E=\frac{1}{2}mv^{2}+\frac{1}{2}kx^{2}## and solving for
aminbpy
An SDOF system (m = 20 kg, k = 350 N/m) is given an initial displacement of
10 mm and initial velocity of 100 mm/s. (a) Find the natural frequency; (b) the
period of vibration; (c) the amplitude of vibration; and (d) the time at which the
third maximum peak occurs.
Ans: 0.666 Hz; 1.502 sec; 25.91 mm; 3.285 sec.
Which Equation should I use to obtain the amplitude of vibration and time for the third maximum pick occur?
Part a and b I got the answer.
That's a harmonic oscillator, isn't it? Calculate the total energy (kinetic plus potential) at the initial moment from the equation ##E=\frac{1}{2}mv^{2}+\frac{1}{2}kx^{2}##, and find out what displacement ##x## it corresponds to if all the energy were potential energy. That way you can find the amplitude of oscillation.
FAQ: Single Degree-of-Freedom Systems
1. What is a single degree-of-freedom system?
A single degree-of-freedom system is a type of mechanical system that has only one independent coordinate or variable to describe its motion. This means that the motion of the system can be fully described by a single parameter, such as position, velocity, or acceleration.
2. What are some examples of single degree-of-freedom systems?
Some examples of single degree-of-freedom systems include a simple pendulum, a mass-spring system, a vibrating guitar string, and a swinging door. These systems have one dominant motion that can be described by a single variable, such as the angle of the pendulum, the displacement of the mass, the displacement of the string, or the angle of the door.
3. How are single degree-of-freedom systems analyzed?
Single degree-of-freedom systems can be analyzed using mathematical models, such as differential equations, to describe their behavior. These models can be solved to determine the motion of the system over time, and parameters such as natural frequency, damping ratio, and response amplitudes can be calculated.
4. What is natural frequency in single degree-of-freedom systems?
Natural frequency is a characteristic property of single degree-of-freedom systems that describes how quickly the system will oscillate when disturbed from its equilibrium position. It is determined by the mass and stiffness of the system and is independent of damping.
5. How does damping affect the behavior of single degree-of-freedom systems?
Damping is a factor that affects the rate of energy dissipation in a single degree-of-freedom system. It can be either positive (dissipative) or negative (amplifying). Damping reduces the amplitude of oscillations and influences the rate at which the system returns to its equilibrium position. A higher damping ratio results in a faster decay of oscillations and a lower amplitude of response.
