Single Direction Applied Force Locking Mechanism
In summary, the conversation is about finding a locking mechanism that can engage with force in a linear direction and then be released with force in the same direction. The only technology that has been mentioned is the spring-loaded retractable pen mechanism, but the person is looking for other options. Suggestions have been made to search for clutch bearings and springs, but the person clarifies that they need a mechanism that can hold two faces in place when an electromagnet pulls them together and can be released with force in the same direction. The conversation also mentions other examples of push to open or close mechanisms such as cabinet door catches and pull cord light switches.
szc
Having trouble researching/discovering any locking mechanisms that engage with force in a linear direction and then allow the engagement to be released with force in the same applied direction. I don't know if it has been done, any help/findings would be greatly appreciated. The only technology I have been able to come up with is the spring loaded retractable pen mechanism.
I think if you search "clutch bearings" and "clutch springs" you might find what you are looking for. Commercial copiers are one place to find the springs (of a small size) any bearing supplier will have clutch bearings. ( they are kinda pricey though )
Likes bsheikho
I don't know if that's quite the application I am looking for. I probably should have explained the application a bit more. I am going to have two separate faces one being an electromagnet pulling the other face towards it. The electromagnet will only have the capabilities to apply force in one direction and I need to be able to hold the face in place once the power is cut from the electromagnet. Then once the mechanism needs to be released I can only apply force in the same direction that the electromagnet originally did.
Likes bsheikho
That kinda twisted my brain ( but that's easy to do:wideeyed: ) but I'll think about it a bit, I suspect someone will answer before I figure it out :rolleyes:, just hang tight. :smile:
Likes szc
Something like a pen?
Some cabinet door catches are push to open, push to close.
Pull cord light switches.
Likes bsheikho
Related to Single Direction Applied Force Locking Mechanism
1. What is a single direction applied force locking mechanism?
A single direction applied force locking mechanism is a mechanical system that allows for the application of force in one direction only. This means that the mechanism will prevent any movement or force in the opposite direction, providing a secure lock.
2. How does a single direction applied force locking mechanism work?
A single direction applied force locking mechanism typically consists of two components - a locking element and a mating element. The locking element is designed to engage with the mating element in a way that allows for force to be applied in one direction, but prevents any movement in the opposite direction.
3. What are the advantages of using a single direction applied force locking mechanism?
One of the main advantages of using a single direction applied force locking mechanism is its simplicity and reliability. It is also relatively easy to manufacture and can be used in a variety of applications, such as securing doors, windows, and other moving parts.
4. What are some common examples of single direction applied force locking mechanisms?
Some common examples of single direction applied force locking mechanisms include latches, bolts, and cam locks. These can be found in everyday objects such as lockers, cabinets, and safes.
5. Are there any limitations to using a single direction applied force locking mechanism?
While single direction applied force locking mechanisms are generally effective, they may not be suitable for all applications. For example, they may not provide enough security for high-risk situations and may require regular maintenance to ensure proper function. Additionally, they may not be suitable for use in environments with extreme temperatures or corrosive materials.
