A Single photon avalanche detector (SPAD) difficulties with photometer
The discussion revolves around the challenges faced in developing a single photon avalanche detector (SPAD) based photometer, particularly its inability to detect continuous illumination or high count rates, which leads to the SPAD going "blind." Initial issues with ordinary avalanche photodiodes (APDs) were noted, but the current focus is on the SPAD's performance, which has improved by adjusting its operating conditions away from the breakdown voltage. The user is also considering replacing carbon film resistors with metal film resistors to enhance measurement accuracy. The application of this technology is aimed at optical SETI for detecting pulsed laser signals, where received signals may be extremely faint. Ongoing adjustments and experiments are necessary to optimize the detector's performance for its intended use.
Benschu
TL;DR Summary
The SPAD and circuitry have been developed over a substantial time. However, the output drops to zero whenever a non-pulsed optical signal is applied.
I have been developing a SPAD based photometer having a 10 ns deadtime, near-zero dark counts, near-zero afterpulsing, and that is temperature independent (within a reasonable range). It works well with photon level pulsed optical signals, (10ns to several microsecond pulse widths at rates up to about 50 kHz), but at higher rates or whenever the illumination is continuous (at any level), the SPAD goes completely blind. Early on I've experienced the same issue with ordinary APDs. The ECL based detector circuitry is happy up to 30 MHz, so not believed to be a factor here.
There is, of course, difficulty observing the SPAD-detector junction because an extra picofarad or two throws measurements completely off.
I am concerned there may be something strange going on there, but at a loss as to how it might be checked. The bias resistors at the SPAD junction are carbon film and I plan to replace them with metal film resistors in the next day or so. Any ideas out there about possible causes for this limitation will be appreciated.
Ben
Astronomy news on Phys.org
What does that mean? A very dim continuous illumination should look like individual photons arriving at random times.
Did you test the single photon deadtime experimentally with two pulses separated by x ns?
Hi mfb,
Yes, using short driving pulses (<15ns), an NIR LED doesn't begin emitting until nearly 15 ns. Also, it is not difficult to approximate the number of photons expected from an LED given the power, distance, beam divergence, efficiency, etc.
I have been using photomultipliers for years with routine single-photon detection sensitivity. SPADs and APDs a bit new to me. The problem with SPAD blindness at high count rates has been found. I have been trying to operate too near the SPAD breakdown voltage. So, that problem is mostly solved. Many compromises are required.
The use for these detectors is for optical SETI searching for pulsed laser signals. If one does all the calculations, it is likely that, for my telescope, a received signal with be less than 100 photons and maybe a lot less. So, the work continues.
Ben.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
