Single-slit Diffraction Problem
In summary, a spy camera is said to be able to read the numbers on a car’s license plate. If the numbers on the plate are 5.0 cm apart, and the spy satellite is at an altitude of 160 km, the diameter of the camera’s aperture is 520 mm.
lingualatina
A spy camera is said to be able to read the numbers on a car’s license plate. If the numbers on the plate are 5.0 cm apart, and the spy satellite is at an altitude of 160 km, what must be the diameter of the camera’s aperture? (Assume light with a wavelength of 550 nm.)
Single-slit diffraction: wsinθ = (where w is the width of the slit, m = 1, 2, 3, ... for destructive interference)
Small-angle approximation: sinθ ≈ tanθ = y/D (where y is the vertical height above the central axis, D is the distance between the slit(s) and the screen) for small θ
Since the goal of the problem is to solve for w, I used the small-angle approximation to set up the following equation: /w = y/D. I then rearranged the variables to isolate w, ending up with w = mλy/D. Now, I know that D = 160 * 103 m and λ = 500 * 10-9 m. I'm having trouble, however, figuring out what to do for m and y. Since the numbers on the plate are 5.0 cm apart, I'm assuming that, every 5.0 cm, we have constructive interference occurring. Since there will definitely be constructive interference along the central axis, I figured that the first-order minimum would occur halfway in-between the central bright fringe and the first-order bright fringe, which would give m = 1 and y = 2.5 cm. However, this does not give me the correct answer; if I try instead to use m = 1 and y = 5.0 cm, this does give me the right answer, but I can't come up with a sketch of the situation that would explain why. Some assistance with the intuition here would really be appreciated.
Thank you very much in advance for your help!
You may find this useful in determining how to proceed.
https://www.boundless.com/physics/textbooks/boundless-physics-textbook/wave-optics-26/diffraction-175/the-rayleigh-criterion-640-6036/
The central maximum for single slit diffraction, (where ## m=0 ## and constructive interference occurs) is the item of interest here. Most of the energy is in this central part of the image which becomes a small blob (instead of a point) of width ## \Delta x=f \Delta \theta ## when focused by the lens with focal length ## f ##. The width of this blob is often taken to be ## \Delta \theta=\lambda/w ##. (Sometimes with a factor like 1.22 in front of ## \lambda/w ##. To actually read the numbers, it will need to have a resolution even better than the ## \Delta \theta=5 \, cm/160 \, km ## that they give you, but that is apparently the ## \Delta \theta ## they want you to use. ## \\ ## Additional info/question that might be helpful: What is the spacing ## \Delta x ## in the focal plane of the lens of two numbers on the license plate that are separated by ## 5 \, cm ##? ## \\ ## And additional item: The far-field diffraction pattern from light incident on the lens (such as perfectly parallel rays which are going through the aperture of width ## w ## (=the width ## w ## becomes essentially a slit width)) gets imaged by the lens in the focal plane of the lens. An angular spread ## \Delta \theta ## in the far-field diffraction pattern gets converted to a distance ## \Delta x ## in the focal plane given by ## \Delta x=f \Delta \theta ##. The light (all parallel rays on the lens) that would go to angle ## \theta ## in the far field winds up being focused at position ## x=f \, \theta ## in the focal plane of the lens. Thereby, the far-field diffraction pattern that would be created by a set of incident parallel rays on the lens winds up as the image that results in the focal plane, rather than getting the perfect focused point that the ray trace theory would give. (Instead of a perfectly focused point, you get a very small focused spot or blob).
Likes scottdave
@scottdave and @Charles Link Thanks very much to both of you for the help; I think I've gotten the right answer now.
Likes scottdave and Charles Link
ZHIHZ said:
Is this diffraction??Help..sorry if I've posted in the wrong place.
Related to Single-slit Diffraction Problem
1. What is single-slit diffraction?
Single-slit diffraction is a phenomenon that occurs when a wave, such as light or sound, passes through a narrow opening or slit. It causes the wave to spread out and create a pattern of bright and dark fringes, known as a diffraction pattern, on a screen placed behind the slit.
2. How is the width of the slit related to the diffraction pattern?
The width of the slit is directly related to the diffraction pattern. The narrower the slit, the wider the diffraction pattern will be. This is because a narrower slit causes the wave to diffract more, resulting in a larger spread of the wave on the screen.
3. What factors affect the diffraction pattern in a single-slit experiment?
The main factors that affect the diffraction pattern in a single-slit experiment are the wavelength of the wave, the width of the slit, and the distance between the slit and the screen. Other factors such as the intensity of the wave and the properties of the screen can also have an impact on the diffraction pattern.
4. How does the single-slit diffraction pattern differ from the double-slit interference pattern?
The single-slit diffraction pattern differs from the double-slit interference pattern in that the former produces a pattern of bright and dark fringes, while the latter produces a series of bright and dark bands. Additionally, the single-slit diffraction pattern is caused by the wave spreading out as it passes through a single slit, while the double-slit interference pattern is caused by the interaction of two waves passing through two slits simultaneously.
5. What applications does single-slit diffraction have in science and technology?
Single-slit diffraction has various applications in science and technology, including in the field of optics, where it is used to study the properties of light and to create optical instruments such as spectrometers. It is also used in the design of microscopes and telescopes to improve their resolution. Additionally, single-slit diffraction is used in engineering to study the behavior of waves and design structures that can manipulate them.
