Singlet and Triplet Terms misunderstanding
In summary: S+1}{3})\lambda^{2}If you have two spin 1/2 particles, each with a total spin of 1/2, then the total angular momentum of the two particles is either zero (single) or one (triplet). Most of the time, the atomic interaction is determined by the total spin of the system, and so it is usually zero in a single state and one in a triplet state. For example, if you have an interaction of the kind:$$ H=\lambda \vec{S}_1\cdot\vec{S}_2,$$then you can write:$$J^2=(S_
Eats Dirt
92
I am a little unclear on why in atomic physics that the total orbital momentum terms have to be specifically singlet or triplet states, for example
G -Singlet
F -Triplet
D -Singlet
P -Triplet
S -Singlet
I think it has to do with the pauli exclusion principle but don't really understand the process.
If someone could walk me through why that would be great! (edit: 2 electron case)
It is simply due to the fact that you are dealing with 2 electrons, i.e. two spin-1/2 particles. When you consider the two electrons system as a whole you are building a new Hilbert space out of the tensor product of the two Hilbert spaces of the single electrons. Let's focus on the spin only. What you are doing is building:
|j,_z\rangle=|1/2,\pm1/2\rangle\otimes|1/2,\pm1/2\rangle,
where [itex]J=S_1+S_2[/itex] is the total spin. Now, it turns out that, in Quantum Mechanics, when you compose two spin-1/2 states, the total angular momentum can be either J=0 (single) or J=1 (triplet). Most of the times the atomic interaction depends on the total spin of the system and so it turns out that it is determined by the fact that the system is in a single/triplet.
where [itex]\lambda[/itex] is coupling constant, then you can write:
J^2=(S_1+S_2)^2=S_1^2+S_2^2+2S_1\cdot S_2 \Rightarrow S_1\cdot S_2=\frac{J^2-S_1^2-S_2^2}{2}=\frac{j(j+1)-3/2}{2}.
Then if you are in a single case [itex]j=0[/itex] and the energy shift is given by [itex]\Delta E_{sing}=-(3/4)\lambda[/itex], while if you are in a triplet [itex]j=1[/itex] and [itex]\Delta E_{tripl}=+(1/4)\lambda[/itex].
Likes vanhees71
Hi, thanks for the reply.
I still don't quite understand how this connects to the total level L values, for example why does the G state exclusively have a singlet
[tex]
^{2S+1}L_{J}
[/tex]
Related to Singlet and Triplet Terms misunderstanding
1. What are singlet and triplet terms?
Singlet and triplet terms are terms used in quantum mechanics to describe the spin states of particles. Singlet terms refer to states where the total spin of a system is 0, while triplet terms refer to states where the total spin is 1.
2. What is the difference between singlet and triplet terms?
The main difference between singlet and triplet terms is the total spin of the system. Singlet terms have a total spin of 0, while triplet terms have a total spin of 1. This difference has important implications in the behavior and interactions of particles.
3. How are singlet and triplet terms used in chemistry?
In chemistry, singlet and triplet terms are used to describe the electronic states of molecules. These terms help predict the reactivity and stability of molecules, as well as the types of chemical reactions they can undergo.
4. Can singlet and triplet terms be interconverted?
Yes, singlet and triplet terms can be interconverted through a process called spin-flip. This involves changing the spin of one or more particles in a system, resulting in a change in the total spin and therefore the term of the system.
5. How can misunderstanding singlet and triplet terms affect research?
Misunderstanding singlet and triplet terms can have significant impacts on research, particularly in the fields of chemistry and physics. It can lead to incorrect predictions and interpretations of experimental data, resulting in wasted time and resources. It is important for scientists to have a clear understanding of these terms to accurately describe and analyze the behavior of particles and molecules.
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
