Singularities of Complex Functions
In summary, the singularities in the finite z plane of the functions are two poles and two 'removable singularities'.
timeforchg1
Determine the location and nature of singularities in the finite z plane of the following functions:
(a) f(z) = (
mimetex.cgi
- 1) sin(z)/[z(z+1)(z+2)(z-3)]
(b) g(z) = [1 + cos(z)]/
mimetex.cgi
Using Cauchy's intergral formulae, referring to the above functions,
Evaluate
i)
mimetex.cgi
f(z) dz, with C : | z + j | = 4 , traversed positively (CCW),
ii)
mimetex.cgi
g(z) dz, with C: | z - 1 | = 2, traversed positively (CCW).
In each case, sketch the required contour C, carefully showing its direction.
(a) f(z) = (
mimetex.cgi
mimetex.cgi
Evaluate
i)
mimetex.cgi
ii)
mimetex.cgi
Hi timeforchg, :)
Let me help you with the second function. :) It is clear that \(z=0\) is the only singular point (since \(g\) is not defined only at \(z=0\)). Now,
\[g(z)=\frac{h(z)}{(z-0)^8}\mbox{ where }h(z)=1+\cos z\]
Note that the function \(h\) is holomorphic everywhere(entire function). Therefore \(z=0\) is a non-essential singularity (pole) of order 8.
\[\oint_C g(z)\,dz=\oint_C\frac{1+\cos z}{z^8}\,dz\]
We know that, \(h(z)=1+\cos z\) is a holomorphic function and that the point \(z=0\) is contained inside the closed contour \(C:~| z - 1 | = 2\). Therefore by the Cauchy's integral formula we get,
\[\oint_C g(z)\,dz=\oint_C\frac{1+\cos z}{z^8}\,dz=\frac{2\pi i}{7!}h^{7}(0)\]
Now can you do the first part yourself? :)
Kind Regards,
Sudharaka.
(a) f(z) = (
mimetex.cgi
Using Cauchy's intergral formulae, referring to the above function, evaluate
mimetex.cgi
with C : | z + j | = 4 , traversed positively (CCW)...
The function...
$\displaystyle f(z)= \frac {(z^{2}-1)\ \sin z}{z\ (z+1)\ (z+2)\ (z-3)}\ $ (1)
... two poles in $z=-2$ and $z=3$ and two so called 'removable singularities' [a concept that in my opinion produces only confusion and that should be removed from the textbooks...] in $z=0$ and $z=-1$. The residues of f(z) are...
$R_{-2}= \lim_{z \rightarrow -2} (z+2)\ f(z)= \frac {3}{10}\ \sin 2$
$R_{+3}=\lim_{z \rightarrow +3} (z-3)\ f(z)= \frac{2}{15}\ \sin 3$
... and both the poles are inside C so that the required integral is...
$\displaystyle \int_{C} f(z)\ dz = 2\ \pi\ i\ (R_{-2}+ R_{+3})$ (2)
Kind regards
$\chi$ $\sigma$
FAQ: Singularities of Complex Functions
What is a singularity of a complex function?
A singularity of a complex function is a point in the complex plane where the function becomes undefined or behaves in an unusual way. This can happen when the function has a pole, essential singularity, or removable singularity at that point.
How do singularities affect the behavior of a complex function?
Singularities can drastically change the behavior of a complex function near that point. For example, a pole can cause the function to approach infinity, while an essential singularity can lead to complex oscillations. Additionally, the presence of a singularity can prevent a function from being analytic at that point.
How are singularities classified?
Singularities can be classified into three types: removable, poles, and essential singularities. A removable singularity is a point where the function can be redefined to make it continuous at that point. A pole is a point where the function approaches infinity. An essential singularity is a point where the function has no limit and oscillates in a complex manner.
What is the relationship between singularities and the derivative of a complex function?
The presence of singularities can affect the differentiability of a complex function. A function with a removable singularity can still be differentiable at that point, while a function with a pole or essential singularity is not differentiable at that point.
How can singularities be identified in a complex function?
To identify singularities in a complex function, we can look for points where the function becomes undefined, infinite, or behaves in an unusual manner. We can also analyze the Laurent series expansion of the function to identify the type of singularity at a particular point.
