tangodirt
- 54
- 1
There is a beam of width 10cm, and vertical reaction loads on each end (x1 = 0cm, x2 = 10cm). Starting from the left end of the beam, we have a vertical distributed load of 2,000 N/m spanning from 0cm to 5cm. Finally, we have a 1,000 N point load located 7.5cm from the left end of the beam.
Through statics, it can be said that the left most reaction load (x1 = 0cm) is of magnitude 325 N while the right most reaction load (x2 = 10cm) has a magnitude of 775 N.
My singularity function for this system is shown below:
[tex]V = 325<x - 0>^{0} - 2000<x - 0>^{1} + 2000<x - 0.05>^{1} - 1000<x - 0.075>^{0} + 775<x - 0.1>^{0}[/tex]
Which, when plotted (my end goal here), works perfectly and as it should. My issue comes when I switch the shear (V) singularity function to a moment function by increasing the exponents by one (as I've been told).
Through integration of the shear singularity function, the moment equation then becomes:
[tex]M = 325<x - 0>^{1} - 2000<x - 0>^{2} + 2000<x - 0.05>^{2} - 1000<x - 0.075>^{1} + 775<x - 0.1>^{1}[/tex]
Which doesn't work quite as well. The moment function falls completely apart, but from every source I've read so far, it shouldn't. Also, if I draw the moment equation by hand (through the "area under the curve" approach), it hardly matches the output of the moment singularity equation.
Any ideas?
Any ideas?
