Sinusoidal Radiation: True or False?
In summary, sinusoidal radiation exhibits a radiation pattern that does not change with distance or time and travels perpendicular to both the electric and magnetic fields. The propagation direction can be determined using the right hand rule and the source of the radiation is oscillating charges. Some of the statements mentioned, including (2), (4), (7), and (8), are correct, while others such as (1), (3), and (5) are incorrect. It is important to carefully consider the properties and characteristics of sinusoidal radiation to accurately determine which statements are true.
xzibition8612
142
Which of the following are true for sinusoidal radiation?
1)The radiation pattern does not change with distance.
2)The radiation travels perpendicular to the electric field.
3)Oscillating charges are not accelerating.
4)The electric field and the magnetic field have the same magnitude at the same point in space.
5)The radiation pattern does not change with time.
6)The radiation travels perpendicular to the magnetic field.
7)The electric field is perpendicular to the magnetic field.
8)The propagation direction of the radiation can be determined from the right hand rule.
9)The source of the radiation is oscillating charges.
I chose (2), (4), (7), (8) and it was marked wrong. Is (9) correct?
One of (2), (4), (7), (8) is not correct. Which one? Also, you missed a correct answer in one of (1), (3), (5), (6).
(4), (6), (7), (8), (9)
These are the correct ones right?
Why do you think each of them is correct?
Why do you think each of the other ones is incorrect?
it's good thanks. The computer marked them right. Thanks again.
So was 4, 6, 7, 8, 9 correct?
What do you think and why? We just don't give answers in this forum.
Related to Sinusoidal Radiation: True or False?
1. Is sinusoidal radiation a type of electromagnetic radiation?
Yes, sinusoidal radiation is a type of electromagnetic radiation that is characterized by a sinusoidal wave pattern.
2. Does sinusoidal radiation travel at the speed of light?
Yes, sinusoidal radiation travels at the speed of light, which is approximately 3 x 10^8 meters per second.
3. Can sinusoidal radiation be harmful to humans?
Yes, sinusoidal radiation can be harmful to humans if exposed to high levels. It can cause tissue damage and increase the risk of certain cancers.
4. Are all forms of radiation considered sinusoidal?
No, not all forms of radiation are considered sinusoidal. Other types of radiation include non-sinusoidal waves, such as square waves and triangular waves.
5. Is it true that sinusoidal radiation is only used in communication and technology?
No, sinusoidal radiation is also used in various other fields, such as medical imaging, power generation, and astronomical observations.
