Siphon problem with above ground water tank/pump
In summary: If so, then the valve is defective and needs to be replaced. If all the heads leak then there is probably an obstruction in the water flow somewhere. Possibly in the pump itself or in the line between the pump and the heads.
saxman2u
Several heads on my irrigation system are leaking when my irrigation pump cuts off. The irrigation pump is 30 ft lower in elevation than the bottom of the 1200 gallon water tank that supplies water to the pump. I keep about 4 feet of water in the tank, so the pump is essentially 34 ft below the water surface. The pump is about 120 feet away in linear distance with a 2" PVC line feeding the pump. The pump has a 1.5" input on it and a 1.25" output on it.
After several years of correct operation, several sprinkler heads are leaking and it is not front low head drainage. Some of lower heads are not even leaking. I can hear water passing through the valve solenoid. It is making a whirring sound, faint but noticeable.
Am I better off to install small check valves under all the sprinkler heads? This is a pain, messy, and time consuming. Or, do I have to install an anti-siphon or vacuum break device up by the water tank?
My pressure to the sprinkler heads is right at 55 PSI with the PCV and the valve solenoid diaphragm is not damaged. I am also unsure as to why the problem just surfaced since I installed the system in 2010?
This question popped up years ago but I would like a few more details with correct equipment and install locations/height/material.
Thanks for your help,
Scott
Based on the mostly complete description, I'll have to assume that the solenoid valve is supposed to stop outflow from the water tank.
So the condition you have is:
1) Water is not to flow when valve is closed. This was proven true in past operation.
2) Water is now flowing when valve is supposed to be closed.
Possible Causes:
A) Water is flowing somewhere other than thru valve.
B) Valve is not closed when it is supposed to be.
C) You are imagining things, there is no water flowing.
If I had to choose the most likely cause it would be B).
Solution most likely to be effective:
Replace the valve.
P.S. For less stringent requirements on the valve, you could mount it at the tank outlet and install a vacuum-breaker just below it. That way the valve has only four feet of head on it rather than 34 feet. But that means the pump will startup dry unless you delay its' start after the valve opens.
Likes billy_joule
Can you confirm that the sprinkler heads are lower than the water level in the tank? In which case it sounds like the problem is due to wear in the pump or the valve causing it to let water by (eg nothing to do with a syphon effect). If that's the situation then fixing the valve should work.
Couple of things here. The lowest sprinkler heads do not leak but higher ones do. You can hear water flowing through the solenoid valve that is supposed to be closed. Sounds like a two fold problem. It should be a given that a closed solenoid valve should not allow fluid to pass through. Points to a defective solenoid valve. But, if that were the case then shouldn't all sprinkler heads leak especially the lower ones? I would bet there is a diaphragm in each sprinkler head that shuts off flow once pressure gets below a certain point. Points to this being defective also. Maybe the components just need a good cleaning.
Perhaps the lower ones don't leak because all the water has escaped (from the higher ones) before it can get to them?
Related to Siphon problem with above ground water tank/pump
1. How does a siphon work with an above ground water tank?
A siphon is a simple mechanism that uses gravity to transfer liquid from a higher point to a lower point. In the case of an above ground water tank, the siphon uses atmospheric pressure to force water out of the tank and into a lower container or area.
2. What is the purpose of a siphon in an above ground water tank?
The purpose of a siphon in an above ground water tank is to allow for the controlled transfer of water from the tank to another location. This can be useful for watering gardens, filling smaller containers, or draining the tank for cleaning or maintenance.
3. How do you set up a siphon in an above ground water tank?
To set up a siphon in an above ground water tank, you will need to create a tube that connects the water in the tank to a lower point. This can be done by submerging one end of the tube in the water and bringing the other end to a lower point. Make sure the tube is completely filled with water and then let gravity do the rest.
4. What are some common problems with siphons in above ground water tanks?
One common problem with siphons in above ground water tanks is air leaks. If air enters the siphon tube, it can break the siphon and prevent the water from flowing. Another issue is blockages in the tube, which can prevent the water from flowing freely.
5. How can you troubleshoot and fix a siphon problem with an above ground water tank?
If you are experiencing issues with your siphon in an above ground water tank, there are a few steps you can take to troubleshoot and fix the problem. First, check for air leaks and blockages in the tube and fix any issues you find. You can also try adjusting the tube's placement or length to improve the siphon's performance. If all else fails, you may need to replace the siphon with a new one.
  • Mechanical Engineering
  • General Engineering
16K
10K
  • Thermodynamics
