the ads 13
- 16
Hi y'all,
I am currently doing research in nuclear physics dealing with cryogenics. We want to pre cool the inner most part of a dewar with liquid nitrogen before we put liquid helium in since it's quite expensive. Once the nitrogen stops boiling off and reaches somewhat of an equilibrium, the excess liquid needs to be siphoned out of the dewar. Our only option is to use a metal tube sticking straight up into the air. In order to siphon the liquid nitrogen out, we need a higher pressure in the dewar than the atmosphere. I go through my calculations with Bernoulli's equations and I seem to get around 1.8 bars needed inside the dewar. That answer seems too high to me and I don't know where I'm going wrong. Here are some specifics:
Total volume flow rate: 2 liters/hour (.002 m^3/hour)
Diameter of metal tube: 3mm
Diameter of Inner Dewar Compartment: 101.6 mm
Density of Liquid Nitrogen: 807.0 kg/m^3
Total Height of Tube: 1.5 m
Height from surface of liquid nitrogen to top of tube: 1 m
I appreciate any help.
Thanks
Thanks
