Size of product given size of reactant?
  • Thread starter Rvngizswt
  • Tags
    Product
In summary: The same is true for the reaction: you get the same number of NH4Cl molecules as the reactants, but they're all combined into one lump.
Rvngizswt
We have this assignment, but the teacher didn't teach us this at all.
"For each of the following balanced chemical equations, calculate how many moles and how many grams of each product would be produced by the complete conversion of 0.56 mol of the reactant indicated in boldface."
Here is one problem, how do I do it?
NH3(g) + HCl(g) → NH4Cl(s)
The reaction is balanced. The two products become one. How do you solve 1+1? Hint: 1+1=2
Borek said:
I find it hard to believe you were not told anything abut stoichiometry.
If you have nothing in your notes and your textbook, try to start here: how to read chemical reaction equation.
She's a very terrible teacher, and the book is very general. So thanks for the help!
Also, what does the (s) and (g) mean in the equation?
You didn't read it all, did you?
(s) for a solid, (g) for a gas. Also (l) for a liquid and (aq) for something dissolved in water.
There's not much to read. Of course I read it all. What did you expect?
You can think of this as pushing two balls of clay into one.
You have 0.56 mol of ammonia gas. It's probably sitting in some flask, and you're pumping in hydrochloric gas from a source. You want to know how much gas to pump in so that you can convert all the molecules to ammonium chloride salt. In other words, all the ammonia molecules in the flask must react with the hydrochloric gas molecules to form the ammonium chloride salt. Therefore, you have to pump in 0.56 mol of hydrochloric gas.
Okay... so how is this useful? The next step is to go find a periodic table. The values in the periodic table are average g/mol values of the elements. Convert all the values to grams to find the masses of each of the chemicals that you're using.
Obviously, since mass is conserved, then the mass of the NH4Cl salt is the combined mass of the NH3 and HCl gasses. However, you still end up with the same number of mols of NH4Cl as each of the reactants. When you push two balls of clay into one, the one clay ball will have twice the mass, but regardless, it's still one clay ball.
Related to Size of product given size of reactant?
1. How does the size of the reactant affect the size of the product?
The size of the reactant can have a direct impact on the size of the product in certain reactions. For example, in a condensation reaction, the size of the product will be larger than the size of the reactants due to the combination of smaller molecules into larger ones.
2. Can a smaller reactant produce a larger product?
Yes, a smaller reactant can produce a larger product in some cases. This can occur in reactions where multiple smaller molecules combine to form a larger product, as seen in polymerization reactions.
3. Is the size of the product always proportional to the size of the reactant?
No, the size of the product is not always directly proportional to the size of the reactant. Other factors such as reaction conditions, stoichiometry, and the specific reaction pathway can also influence the size of the product.
4. What role does the size of the reactant play in determining the product yield?
The size of the reactant can impact the product yield in some cases. In reactions where larger molecules are desired, a larger reactant may result in a higher yield as it provides more building blocks for the product. However, in other cases, the size of the reactant may not have a significant effect on the product yield.
5. How does the size of the product affect its properties?
The size of the product can greatly influence its properties. Larger products may have different physical and chemical properties compared to smaller products, such as increased stability or altered reactivity. Additionally, the size of the product can also impact its solubility and ability to cross biological barriers.
  • Mechanical Engineering
