- #36
Asymptotic
- 781
- 528
OmCheeto said:That's kind of what I inferred above:Not with a fixed resistance. In that case we would always get the same power output.
ps. Asymptotic was correct. The resistance of my coffee maker element rose from 14.4Ω to 15.0Ω when void of water. Observed wattage dropped from 979 to 938.
pps. On a humorous side note, my coffee maker is so old, it is ungoogleable*. The closest I can come is an ad on Etsy:
Overview
- Vintage item from the 1970s
* Other are welcome to try:
PROCTOR-SILEX
2209 SULPHUR SPRING ROAD
BALTIMORE,MD.21227
120 VOLTS A.C.ONLY
1000 WATTS 60 HZ
MADE IN U.S.A.
TYPE A06
MODEL A6126
SERIES A 3288
ppps. I knew it was probably old when I saw "MADE IN U.S.A.", but not that old.
That sounds about right. Immersed, element wire temperature won't rise very much above the temperature of the water surrounding the heater sheath, and limits how much the electrical resistance changes. I wonder how much the longevity of your coffee maker is due to wattage rating versus robust construction; lower power rated elements tend to last longer.
Better check my math (gray-haired American engineers often think in BTU), but about 234 watts are required to increase 15°C water in a 10 cup (US measure; 2.5 liter) coffeemaker to 100°C at sea level. Ignoring thermal losses, this takes about 14 minutes at 1000 watts, and 9.3 minutes at 1500W, and may help explain why in this impatient age the more modern kettle was designed at a higher power rating.
