Sketch and identify the surface
In summary, the given equation can be simplified by completing the square in x and z. The resulting equation is 4(z-12)^2 - y^2 = 99, with the center at (12,0) and a = sqrt(4/99). It is important to be careful with the algebra when completing the square.
goonking
434
9x2 − 18x + 4z2− 24z − y2 + 45 = 0
so let's start with the zy trace, setting x=0
we are left with:
4z2 - 24z - y2 = -45
completeing the square gives :
4z2 - 24z + 144 - y2 = -45 +144
4(z-12)2 - y2 = 99
divide both sides by 99
4(z-12)2 /99 - y2/99 = 1
so the center is at (12,0)? is a = sqrt of (4/99)?
Don't be too quick to set x=0. Keep all the variables, and complete the square in both x and z and see what you get. Be careful on the algebra in completing the square, the above effort seems incorrect.
we are left with:
You have a mistake in the line above. Completing the square is easier if you take out the common factors first.
In addition to your work in finding the various traces, you should complete the square in x and z in the original equation, as David Moore advises.
goonking said:
4(z-12)2 - y2 = 99
Related to Sketch and identify the surface
What is the purpose of sketching and identifying a surface?
The purpose of sketching and identifying a surface is to visually represent and analyze the physical characteristics and properties of an object or material. This can help scientists better understand its composition, structure, and behavior.
How do you sketch and identify a surface?
To sketch and identify a surface, scientists use various techniques such as microscopy, spectroscopy, and imaging. These tools allow them to observe and measure the surface at different scales and gather information about its topography, chemical composition, and other properties.
What are the benefits of sketching and identifying a surface?
Sketching and identifying a surface can provide valuable insights into the structure and properties of a material, which can be useful for various scientific fields such as materials science, geology, and biology. It can also aid in product development, quality control, and forensic investigations.
Can sketching and identifying a surface be done on any material?
Yes, sketching and identifying a surface can be done on a wide range of materials, including solids, liquids, and gases. However, the techniques and tools used may vary depending on the type of material and its properties.
What are some common applications of sketching and identifying a surface?
Some common applications of sketching and identifying a surface include analyzing the structure and composition of rocks and minerals, studying the topography of biological surfaces, and characterizing the quality and properties of industrial materials. It is also used in the development of new materials and products.
