Sketch Inequality: Region of $(x,y)$ Points
  • MHB
  • Thread starter Dethrone
  • Tags
    Inequality
In summary, the region in the plane consisting of all points $(x,y)$ such that 2xy\le x-y\le x^2+y^2 exists when x>y and when x<y. When x>y, the inequality can be divided into $x^2+y^2-\left| x-y \right|\ge 0$ which takes the form of a curve when plotted. When x<y, the inequality can be divided into $x^2+y^2+y-2xy$ which takes the form of a curve when plotted. The region of interest is outside of the curve when x>y. The region of interest is inside of
Dethrone
717
From the differentiation section of my calculus textbook:
Sketch the region in the plane consisting of all points $(x,y)$ such that
$$2xy\le\left| x-y \right|\le x^2+y^2$$
I have tried to look at the cases:
Case 1: $x>y$
$$2xy\le x-y\le x^2+y^2$$
$$0\le (x-y)-2xy\le x^2+y^2-2xy$$
Now I have tried to split that by looking at what it needs to satisfy, but I'm not sure if this is correct:
1)
$$0\le x^2+y^2-2xy$$
$$0\le (x-y)^2$$
$$y\le x$$
2)
$$0\le (x-y)-2xy$$
3)
$$x-y \le x^2 +y^2$$
But something doesn't seem right...any hints? :D
hey (Wave)
you can start by sketching the curve $x^2+y^2-\left| x-y \right|= 0$
sketch the graph and you'll notice it looks like two circles attached kind of.
then take a test point like (0.5,-1) inside the loop. put it into the inequality $x^2+y^2-\left| x-y \right|\ge 0$ solve that and you'll find that the solution is false since the number you come up with on the LHS will be less than 0 instead. so you shade the region outside of the loop.
then sketch the curve $2xy-\left| x-y \right|=0$
then take the test point (0.5,-1) and plug into $2xy-\left| x-y \right|\le 0$
the solution to this is true since the left side IS less than the right sides so you sketch the inside of the curve.
now just merge the two sketches together. :eek:
Thanks so much Pippy! (flower)
I got it now...and it required a bit of neat factoring too :D
Like:
$$x^2+y^2-x+y=0$$
$$x^2-x+y^2+y=0$$
$$\left(x-\frac{1}{2}\right)^2+\left(y+\frac{1}{2}\right)^2-\frac{1}{2}=0$$
Like:
$$x^2+y^2-x+y=0$$
$$x^2-x+y^2+y=0$$
$$\left(x-\frac{1}{2}\right)^2+\left(y+\frac{1}{2}\right)^2+\frac{1}{2}=0$$
I am certain you mean:
\(\displaystyle \left(x-\frac{1}{2}\right)^2+\left(y+\frac{1}{2}\right)^2-\frac{1}{2}=0\)
Please post your solution so that we can have it as a reference for others who may need help :eek:
Thank you (Giggle)
Here is my solution, as promised:
Problem:
$$2xy\le |x-y| \le x^2+y^2$$
Solution:
Focusing on the right side of the inequality:
$$|x-y| \le x^2+y^2$$
$$0\le x^2+y^2-|x-y|$$
Case 1: \(\displaystyle x \ge y\)Case 2: \(\displaystyle x<y\)
$$x^2+y^2-(x-y) \ge 0$$
$$\left(x-\frac{1}{2}\right)^2+\left(y+\frac{1}{2}\right)^2 \ge \frac{1}{2}$$
$$x^2+y^2+(x-y) \ge 0$$
$$\left(x+\frac{1}{2}\right)^2+\left(y-\frac{1}{2}\right)^2 \ge \frac{1}{2}$$
Both of these cases take the shape of a circle and the region of interest is outside of the circle.
Fig. 1
Now, focusing on the left side of the inequality:
$$2xy \le |x-y|$$
$$2xy-|x-y| \le 0$$
Case 1: \(\displaystyle x \ge y\)Case 2: \(\displaystyle x < y\)
$$2xy-(x-y) \le 0$$
$$-x+2xy+y \le 0$$
Rearranging, we see that:
$$x>-\frac{1}{2} \text{ when } y \le \frac{x}{2x+1}$$
$$x<-\frac{1}{2} \text{ when } y \ge \frac{x}{2x+1}$$
$$2xy+(x-y) \le 0$$
$$2xy+x-y \le 0 $$
Similarly,
$$x>\frac{1}{2} \text{ when } y\le -\frac{x}{2x-1}$$
$$x<\frac{1}{2} \text{ when } y \ge -\frac{x}{2x-1}$$
Fig. 2
Concatenating our results, we obtain the below graph. (Note that in order to satisfy both plots, fig. 1 cuts into fig. 2.)
Thanks, Pippy! :D
FAQ: Sketch Inequality: Region of $(x,y)$ Points
What is "Sketch Inequality: Region of $(x,y)$ Points"?
"Sketch Inequality: Region of $(x,y)$ Points" refers to a visual representation of a mathematical inequality in two variables, x and y. It shows all the possible values of x and y that satisfy the inequality and form a region on a graph.
How do you sketch an inequality region?
To sketch an inequality region, plot the boundary line of the inequality on a graph. Then, determine which side of the line represents the solution to the inequality. Finally, shade the appropriate side of the line to indicate the region of $(x,y)$ points that satisfy the inequality.
What is the purpose of sketching an inequality region?
The purpose of sketching an inequality region is to visually represent the solution set for a mathematical inequality. It helps to better understand the relationship between the variables and the conditions for the inequality to be true.
How do you determine which side of the boundary line to shade?
To determine which side of the boundary line to shade, choose a point that is not on the line and substitute its x and y values into the original inequality. If the resulting inequality is true, then shade the side of the line that contains that point. If the resulting inequality is false, then shade the other side of the line.
Can an inequality region have a curved boundary?
Yes, an inequality region can have a curved boundary. This occurs when the inequality involves quadratic or higher order terms in x and y. The process for sketching the region is the same, but the boundary line will be a curve instead of a straight line.
