Sketch the curve with the given polar equation. θ = −pi/6?
In summary, the given polar equation of θ = −pi/6 represents a straight line passing through the origin and making an angle of −π/6 with the polar axis. There was some uncertainty about the direction of the line, but it was confirmed to be in the direction of \.
carl123
56
I know for certain that its a straight line that passes through the origin but what I'm not sure is if its like this \ or like this /
This curve consists of all points $(r, \theta )$ such that the polar angle $\theta$ is $-\frac{\pi}{6}$.
It is the straight line that passes through the origin $O$ and makes an angle of $-\frac{\pi}{6}$ with the polar axis.
Thanks for your reply, by what you said, I'm assuming the line should be like this \ then
Yes. (Yes)
Ok, thanks
FAQ: Sketch the curve with the given polar equation. θ = −pi/6?
What is a polar equation?
A polar equation is a mathematical representation of a curve or shape in the polar coordinate system. In this system, points are described using a distance from the origin and an angle from a reference line, rather than using x and y coordinates.
How do you plot a polar equation?
To plot a polar equation, you can use a graphing calculator or manually plot points by substituting values of theta into the equation and converting them to Cartesian coordinates. Alternatively, you can use the symmetry and periodicity of polar equations to plot points in one quadrant and then reflect or rotate them to complete the graph.
What does θ = −pi/6 represent in a polar equation?
θ = −pi/6 represents an angle of -π/6 radians or -30 degrees. This means that for every value of r (distance from the origin), the point will lie on a line that makes a -30 degree angle with the reference line.
How do you determine the shape of a curve from a polar equation?
The shape of a curve can be determined by analyzing the values of r in relation to theta. If r is a constant value, the curve will be a line. If r is a function of theta, the curve will be a spiral. If r is a combination of sine or cosine functions, the curve will be a rose curve or a cardioid shape.
Can a polar equation be converted to a Cartesian equation?
Yes, a polar equation can be converted to a Cartesian equation. This can be done by using the equations x = r cosθ and y = r sinθ to replace r and θ in the polar equation. The resulting equation will be in the form of y = f(x), which can be plotted on a Cartesian coordinate system.
