Sketch the following set of points in the xy plane
By the way, it is not division by 0 that is the problem. It is division by expressions that can be zero. And 0 divided by 0 is undefined.
Rijad Hadzic
321
[itex] {(x,y) ∈ ℝ^2 : (y-x)(y+x) = 0 } [/itex]
[/B]
Is the reason the answer is the union of y = -x and y = x because if you divide (y-x)(y+x) = 0 by y-x you get y = -x and if you divide (y-x)(y+x) = 0 by y+x you get y = x?
and if you multiply (y-x)(y+x) = 0 by any constant, after you divide by the factors you will get the same solutions anyways?
That is right. I'm not sure it you have to go into that much detail. When numbers are multiplied together to get zero, one of the factors must be 0. Your book or class notes may state that as a theorem or fact that you can reference without an explanation. Your explanation goes into detail about it, what is good to know in any case, but I don't know if it is required.
PS. A good thing to learn is to use the theorems in the book rather than trying to figure everything out from scratch. Use the tools.
[/B]
You can not divide the equation by an expression which can be zero. So explain the solution {x=y} ∪ {y=-x } in the following way: When a product is zero one of the factors must be zero. So either x-y = 0 or x+y =0 (or both) .
You can multiply an equation by any non-zero constant. But why do you want to multiply it?
So
( (y-x)(y+x) ) / (y+x) = 0 / (y+x)
would not be a valid expression? I thought in the case when the numerator is already 0 you can divide by an expression that's = 0>You can multiply an equation by any non-zero constant. But why do you want to multiply it?
Ah it was just an observation I noticed I guess it doesn't really have any relevance.
CORRECTION: I had to cross out some errors and insert corrections.
It's ok where the divisor is not zero. So that is only a problem at (0,0) when ##y=\pm x##. The other points are ok and the (0,0) point is easy to handle separately.
PS. This logic is only needed to show that there can not be other points in the graph. To prove that ##(y-x) \cdot 0 = 0## only requires the definition of 0.
Rijad Hadzic said:
So
No. it is not valid. You must no divide with zero.
If y+x=0, y=-x. If you perform the division, you get y-x=0, that is, y=x. And both equations can be valid only when x=y=0. But y=-x means that y-x= -2x, with any y, so y-x is not zero.
FactChecker said:
It's ok where the divisor is not zero. So that is only a problem at (0,0). The other points are ok and the (0,0) point is easy to handle separately.
well, what is sin(x)/x at x=0?
You can multiply anything with zero, and the result will be zero. But you must not divide by zero.
It's undefined at x=0, but defined everywhere else. Just because x=0 is a special case does not prevent division everywhere else. And the special case of x=0 is easy to handle separately, if needed.
So I would be fine to do it as long as I'm not looking at the point that gives me x=0?
Sorry, I was wrong in post #5 and will correct it.
In post #8, when I said x=0, I was referring to the sin(x)/x example of post #7. You would have to worry about any step where you divide by ##0=(y-x)## or by ##0=(y+x)##. So that is why I stated in post #5 that your logic would work better to show that any other point (where ##y \neq \pm x##) was not in the graph. At those points, there is no division by 0.
Dividing by x+y is allowed only if you state that x≠-y, and dividing by x-y is allowed if you say that x≠y.
Note what I said in Post #3. Do not divide by anything, just refer to the law that multiplication with zero yields zero. The reverse is also true: when a product is zero at least one of the factors must be zero.
Likes Rijad Hadzic
Related to Sketch the following set of points in the xy plane
1. What is the xy plane?
The xy plane is a two-dimensional coordinate system that is used to plot points and visualize mathematical relationships between variables, specifically in the fields of geometry and algebra.
2. How do I plot points on the xy plane?
To plot points on the xy plane, you will need to have two coordinates for each point - the x-coordinate and the y-coordinate. The x-coordinate represents the horizontal position on the plane, while the y-coordinate represents the vertical position. You can then use a ruler and a pencil to mark the points on the plane, or use a computer program or graphing calculator to plot the points automatically.
3. What does it mean to sketch a set of points in the xy plane?
Sketching a set of points in the xy plane means visually representing them on the plane by marking their positions with dots or crosses. This allows us to see the relationship between the points and understand any patterns or trends.
4. How is the xy plane used in mathematics?
The xy plane is used in mathematics as a visual representation of mathematical concepts and relationships. It is especially useful in graphing functions, solving equations, and analyzing data. The xy plane is also a fundamental tool in geometry, as it allows us to visually understand and solve geometric problems.
5. What are some examples of real-life applications of the xy plane?
The xy plane has many real-life applications, such as in map-making, navigation, and engineering. It is also used in fields such as economics, physics, and biology to graph and analyze data. Additionally, the xy plane is used in video games and animation, as it allows for the creation of 2D graphics and animations.
9K
