Sketch the graph of an invertible function
In summary, to sketch the graph of an invertible function that intersects its inverse in exactly three points, you need to choose a function that is injective and has a monotonic graph. You can use the reflection of the graph in the line x=y to find the inverse, and the points of intersection between the function and its inverse will have the common property that f(x)-x=0 for exactly three values of x. An example of such a function is xn, where n is any odd integer greater than 1.
CrossFit415
160
Sketch the graph of an invertible function f(x) that intersects its inverse in exactly three points.
I don't know where to start... Can I pick any function to start with?
You can't choose any function. If, for example, you choose the function y=x2 then x=2 -> y=4 and x=-2 -> y=4. Clearly this function doesn't have an inverse because given a value for y (other than 0) there are two corresponding values for x.
You need to choose a function y=f(x) with the property that any two different values of x always yield two different values for y. Such functions are called injective functions and have graphs that are monotonic (i.e. either increasing or decreasing but not both).
Lastly, to find the inverse of such a graph, you need to reflect it in the line x=y (the 45 degree line). Try this with some examples and look at what all of the points of intersection between the function and its inverse have in common--that should help you to figure out how to get three points of intersection.
This is an interesting problem because from what I remember functions and their inverses only intersect on the identity function y=x
Yes, that's right. So in order to satisfy "intersects its inverse in exactly three points" there must be exactly three values of x such that f(x)= x. That is the same as saying f(x)- x= 0 for exactly three values of x. However the problem is making sure f is invertible then. You need to go from each such x to the next without having negative slope.
My first thought was to make f(x)- x a cubic. It's easy to construct a cubic that is 0 at three given values but a little harder to make sure it is always increasing. (Actually, there is a very simple example!)
Related to Sketch the graph of an invertible function
1. What is an invertible function?
An invertible function is a function that has a one-to-one correspondence between its input and output values. This means that for every input there is a unique output, and for every output there is a unique input. In other words, an invertible function is a function that can be reversed.
2. How do you sketch the graph of an invertible function?
To sketch the graph of an invertible function, you need to plot points on a coordinate plane. The x-axis represents the input values, while the y-axis represents the output values. You can then connect the points to create a smooth curve. It is important to keep in mind that an invertible function must pass the horizontal line test, meaning that no horizontal line intersects the graph more than once.
3. What are the characteristics of the graph of an invertible function?
The graph of an invertible function is a smooth curve that passes the horizontal line test. This means that it has no sharp turns or corners, and no horizontal line intersects the graph more than once. Additionally, the graph will have both positive and negative values along the y-axis, as an invertible function can have both positive and negative inputs and outputs.
4. Can an invertible function have more than one inverse?
No, an invertible function can only have one inverse. This is because the inverse of a function must also be a function, and a function can only have one output for each input. If there were more than one inverse, it would violate the one-to-one correspondence that defines an invertible function.
5. How do you algebraically find the inverse of a function?
To algebraically find the inverse of a function, you can follow these steps:
  1. Write the function in the form y = f(x).
  2. Switch the x and y variables, so that the equation becomes x = f(y).
  3. Solve for y in terms of x.
  4. The resulting equation will be the inverse function, written as y = f-1(x).
