Sketch the graph of the function f(x)=square root X
In summary: Yes, for the second equation, the y-values will be negative. This is because the negative sign in front of the function, along with the negative sign inside the function, will result in a positive value for x, but a negative value for y. This creates the reflection about the line y = x.
Aka
a) sketch the graph of the function f(x)=square root X
b) on the same set of axes, graph y=f^-1(x), y=-f^-1(-x)
so I did a chart, but i don't know if its right...I don't think its right :confused:
f(x)=squareroot x
X Y
0 0
1 1
4 2
9 3
y=f^-1(x)
X Y
0 0
1 -1
4 -2
9 -3
y=-f^-1(-x)
X Y
0 0
-1 1
-4 2
-9 3
and i don't understand the question
if the two graph of y=-f^-1(-x) is drawn from the graph of y=f(x) by a single reflection, what is the equation of the reflection line?
Thanks
Mathematics news on Phys.org
The graph of the inverse function will be the reflection of the function about the line y = x which amounts to exchanging the values of x and y in your tables and adjusting accordingly for the negative of the inverse.
f(x)=squareroot x
X Y
0 0
1 1
4 2
9 3
Yes, this is correct.
y=f^-1(x)
X Y
0 0
1 -1
4 -2
9 -3
No, this is y= -f(x), not y= f-1(x), the inverse function.
To get the inverse function, just swap the x and y columns.
What is the "opposite" of square root?
[/quote]y=-f^-1(-x)
X Y
0 0
-1 1
-4 2
-9 3 [/quote]
see above.
Thanks
I don't understand "the two graph". Are you sure that you have copied the problem correctly? Draw the graphs as you were told two. Is there some line so that "flipping" the first graph over that line gives the second graph?
^ Thanks
sorry, I did not coppy it corrently, it's not supposed to have the two in it :P
so is it like this?
y=f^-1(x)
X Y
0 0
1 1
2 4
3 9
y=f^-1(-x)
X Y
0 0
-1 1
-2 4
-3 9
Aka said:
^ Thanks
so is it like this?
y=f^-1(x)
X Y
0 0
1 1
2 4
3 9
y=f^-1(-x)
X Y
0 0
-1 1
-2 4
-3 9
Yes, that's better. But, I believe you forgot the negative in front of the f^-1 in the second equation. Shouldn't that be y = -f^-1(-x)?
^ yes, it should
so the y values will be negative
Related to Sketch the graph of the function f(x)=square root X
1. What is the domain of the function f(x)=square root x?
The domain of this function is all non-negative real numbers, as the square root of a negative number is undefined.
2. How do I graph the function f(x)=square root x?
To graph this function, you can plot a few points by choosing values for x and finding the corresponding y values by taking the square root. Then, connect the points with a smooth curve.
3. What is the range of the function f(x)=square root x?
The range of this function is all non-negative real numbers, as taking the square root of any non-negative number will result in a non-negative number.
4. What is the x-intercept of the function f(x)=square root x?
The x-intercept of this function is (0,0), as the square root of 0 is 0.
5. How do I determine the slope of the graph of f(x)=square root x?
Since this function is not a straight line, it does not have a constant slope. However, you can calculate the slope of the tangent line at a specific point by finding the derivative of the function.
