Sketch the graphs of the functions - Calculus question
In summary: However, it is always a good idea to double-check your work and calculations to ensure accuracy. You can also ask for help if you are unsure about any particular part.
Mary4ever
Sketch the graphs of the functions. Indicate intervals on which the function is increasing, decreasing, concave up, or concave down; indicate relative maximum points, relative minimum points, points of inflection, horizontal asympototes, vertical asymptotes, symmetry, and those intercepts that can be obtained conveniently:
y=x^4 - 4x^3 - 20x^2 +150
This is the solution I have:
This is a polynomial of degree 4, so there are no asymptotes.
The function has no symmetries.
dy/dx = 4x^3 - 12x^2 - 40x
d^2y/dx^2 = 12x^2 - 24x - 40
dy/dx = 4(x^3 - 3x^2 - 10x) = 4x(x-5)(x+2)
There are 0s at x = -2, 0, and 5
Thus, there are three critical points for a 4th degree polynomial.
As the function goes to infinity as x goes to plus or minus infinity, we know that
the function decreases on (-infinity, -2), increases on (-2, 0), decreases on (0,5), and increases on (5,infinity)
f(-2) = (-2)^4 -4*(-2)^3 - 20*(-2)^2 + 150 = 16 + 32 - 80 + 150 = 118
There is a local minimum at (-2, 118)
f(0) = 150
There is a local maximum at (0, 150)
f(5) = (5)^4 -4*(5)^3 - 20*(5)^2 + 150 = 625 - 500 - 500 + 150 = -225
There is a local minimum at (5, -225)
The y-intercept is 150
The 0s are approximately 2.5139 and 6.5252
Finally, as the second derivative is 12x^2 - 24x - 40 = 4(3x^2 - 6x - 10), the inflection points are
1 plus or minus sqrt(39)/3 is approximately -1.08166599946613 and 3.08166599946613
As the second derivative is quadratic with a positive leading coefficient, we then know that
the function is concave up on (-infinity, 1 - sqrt(39)/3) or (-infinity, -1.08166599946613 ) and
(1 + sqrt(39)/3,infinity) or (3.08166599946613, infinity) and
concave down on (1 - sqrt(39)/3,1 + sqrt(39)/3) or (-1.08166599946613,3.08166599946613)
But I am not sure if it is correct. Please help
Welcome to PF!
Hi Mary4ever! Welcome to PF! :smile:
(try using the X2 button just above the Reply box :wink:)
Yes, that all looks fine. :smile:
(I haven't checked the y coordinate calculations)
What is worrying you about that? :confused:
Could you please double-check it because I need to make sure everything is correct? Thank you!
This all looks good, based on inspection of the graph and a little help from WolframAlpha.
Related to Sketch the graphs of the functions - Calculus question
1. What exactly does it mean to "sketch the graphs of functions" in calculus?
Sketching the graphs of functions in calculus means to visually represent the relationship between a function's input (x) and output (y) values. This is typically done on a coordinate plane, with the x-axis representing the input values and the y-axis representing the output values.
2. How do I determine the shape of a function's graph?
The shape of a function's graph is determined by the function's equation and its behavior as the input values (x) change. For example, a linear function will have a straight line graph, while a quadratic function will have a parabolic shape. The degree and leading coefficient of a polynomial function also play a role in determining its graph's shape.
3. What information can be gathered from a function's graph?
A function's graph can provide valuable information such as the domain and range of the function, the x and y intercepts, the symmetry of the graph, and the location of any extrema (maximum and minimum points). It can also give insights into the behavior of the function as x approaches positive or negative infinity.
4. Are there any shortcuts or tips for sketching a function's graph?
One tip for sketching a function's graph is to first identify any critical points, such as points where the function changes direction or crosses the x or y axis. Then, plot a few points on either side of these critical points to get a sense of the overall shape of the graph. Additionally, knowing the general shape of common functions, such as linear, quadratic, and exponential, can also be helpful in sketching their graphs.
5. Can a function have more than one possible graph?
No, a function can only have one graph. This is because a function must have a unique output (y) value for every input (x) value. If a function had more than one possible graph, it would not pass the vertical line test, which is a rule for determining if a relation is a function or not.
