Sketch the region of |x-y|+|x|-|y| <= 2
  • MHB
  • Thread starter Dethrone
  • Tags
    Sketch
In summary, the region in the plane defined by the inequality $|x-y|+|x|-|y| \le 2$ can be broken down into quadrants, with the solution being point-symmetric. By applying the triangle inequality, we can derive the inequalities $|x - y| \leq 1$ and $|x| - |y| \leq 1$ in each quadrant, but these only give a subset of the solution. Therefore, to find the full solution, we must go through each quadrant individually.
Dethrone
717
Sketch the region in the plane consisting of all points (x, y) such that $|x-y|+|x|-|y| \le 2$.
This looks like it involves the triangle inequality, but can anyone point me in the right direction? :D
you got to solve it quadrant by quadrant
I think I got it!
Case 1: Quadrant 1
$x>0$, $y>0$
Subcase 1: $x>y$
$$x-y+x-y \le 2$$
$$x-2 \le y$$
Subcase 2: $y>x$
$$y-x+y+x \le 2$$
$$y \le 1$$
Continue with the other quadrants, and the answer follows :D
Edit: I just checked Wolfram Alpha...maybe I'm not (Crying)
Will I have to square both sides and expand? Whoops, I made an arithmetic mistake.
By triangle inequality,
$$|x - y| + |x| - |y| \leq 2|x-y| \leq 2$$
Thus I get $|x - y| \leq 1$.
ineedhelpnow said:
im looking at how the problem was done somewhere else. i don't think you're on the right track. your correct in terms of identifying the quadrants.
x-y+x-y>2
2x-2y>2
2(x-y)>2
x-y>1
Is it not $x-y+x-y \le 2$?
I got $x-1 \le y$
$x \ge y$
$\left| x-y \right| + \left| x \right| - \left| y \right| = 2(x-y) \le 2$
$x-y \le 1$ which is the same as $y \ge x-1$
Can you elaborate on this? (Wondering)
ineedhelpnow said:
$x \ge y$
Doing the same when $y \ge x$
We have
$$-(x-y)+x+-y \le 2$$
$$ - x + y + x - y \le 2$$
$$ 0 \le 2$$
Am I done with this quadrant, or is there more work to be done?
Well, what to elaborate? The triangle inequality gives $|x - y| \geq |x| - |y|$, no?
From the triangle inequality $\big||a|-|b|\big| \le \big|a-b\big|$ we can get:
$$|x - y| + |x| - |y| \leq 2|x-y|$$
and we have the original inequality:
$$|x - y| + |x| - |y| \leq 2$$
However, if we combine them like you did, we only get a subset of the solution.
I am such an idiot. I meant
$$2 \geq |x - y| + |x| - |y| \geq 2(|x| - |y|)$$
Thus, $|x| - |y| \leq 1$.
This is another application of the same triangle inequality.
Any point in the solution will satisfy that inequality.
However, that only means that it is a super-set of the solution.
Still not the solution itself.To properly find the solution, I believe we have to go through the quadrants one by one.
The triangle inequalities do not really help, because they do not give a conclusive solution.
We can skip 2 quadrants though, since the solution will be point-symmetric.
That is, $(x,y)$ is a point in the solution if and only if $(-x,-y)$ is in the solution.
However, that only means that it is a super-set of the solution. Still not the solution itself.
I was aware of that. I am just stating what I intended to write in the first post.
I reckon there is no smart way to find the solutions :p
Yep.
You are done with the first quadrant. ;)
FAQ: Sketch the region of |x-y|+|x|-|y| <= 2
What does the given inequality represent graphically?
The given inequality represents a region on a coordinate plane where the absolute value of the difference between x and y, plus the absolute value of x, minus the absolute value of y, is less than or equal to 2. In other words, it represents all the points that satisfy this inequality.
How can I graph this region?
To graph this region, you can start by rewriting the inequality in terms of the four quadrants on a coordinate plane. Then, you can plot the boundary lines, which will be in the shape of a square with sides of length 2. Finally, you can shade in the region that satisfies the inequality.
What is the significance of the absolute value signs in this inequality?
The absolute value signs indicate that the values inside them can be either positive or negative and still satisfy the inequality. This allows for more flexibility in the graphed region, as it can include points in all four quadrants.
Can this inequality be written in a simpler form?
Yes, this inequality can be simplified to |x| + |y| <= 2. This form shows that the region is symmetric about the x and y axes and can be useful for graphing or finding solutions algebraically.
How can I use this inequality in real-life scenarios?
This type of inequality can be used to represent constraints in optimization problems, such as determining the maximum or minimum value of a function within a given region. It can also be used in economics to represent budget constraints or production possibilities.
