MHB Sketch the sinusoidal graphs that satisfy the properties
To sketch the sinusoidal graph with a period of 4, amplitude of 3, and an equation of the axis at y = 5, the maximum value will be 8 and the minimum value will be 2. The angular velocity $\omega$ can be calculated using the formula $\omega = \frac{2\pi}{T}$, resulting in $\omega = \frac{\pi}{2}$. The sinusoidal function can be expressed as $f(x) = 3\sin\left(\frac{\pi}{2}x\right) + 5$. This function will complete 2 cycles within the specified period of 4. The graph will oscillate between the maximum and minimum values around the axis at y = 5.
eleventhxhour
12a) Sketch the sinusoidal graphs that satisfy the properties below:
Period: 4
Amplitude: 3
Equation of the Axis: y = 5
Number of Cycles: 2
So, I know how to graph sinusoidal functions, but I can't figure out the max and min that would satisfy both the equation of the axis and the amplitude listed.
Mathematics news on Phys.org
Let's start with the angular velocity $\omega$. For a sinusoid of the form:
$$f(x)=\sin(\omega x)$$
The period is:
$$T=\frac{2\pi}{\omega}$$
This comes from:
$$f(x)=\sin(\omega x)=\sin(\omega x+2\pi)=\sin\left(\omega\left(x+\frac{2\pi}{\omega}\right)\right)=f\left(x+\frac{2\pi}{\omega}\right)=f(x+T)$$
So, letting $T=4$, what must $\omega$ be?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
