shashaeee
- 30
A simple type of blinking light circuit can be constructed using a neon lamp. The circuit shown here has a 4.0 μF capacitor in parallel with a neon lamp. When the voltage is low in the RC portion of the circuit, the lamp does not conduct electricity. Therefore, it is effectively not there from an electrical point of view. The RC circuit will then charge from the 110 V power supply. However, when the voltage across the capacitor reaches 75 V, the neon will ionize very quickly and the neon lamp will become a very good conductor, and will immediately discharge the capacitor. The energy stored in the capacitor will be given off as a flash of orange light, making this a useful circuit. After the flash, the charging process will start once more since the voltage will again be low.
a. Determine the flash frequency with the resistance value shown.
b. Make a sketch of the voltage across the capacitor versus time in such a
circuit, showing several periods.
I used the formula:
VC=VO(1-e-t/RC)
and solved for t and frequency.
I'm more concern with the sketch. Correct me if I'm wrong.
So far, I have the t of the charging process. That means I have to solve the t of the discharging process using the formula:
VC=VOe-t/RC
so then my graph can look like: / (charging) \ (discharging) / (charging) \ (discharging) ?
I used the formula:
VC=VO(1-e-t/RC)
VC=VOe-t/RC
