Sketching exponential curves with complex numbers
In summary, the conversation discusses how to sketch y as a function of t for t≥0 when given the equation y= e(0.5t + i(√7/2)t) - e(0.5t-i(√7/2)t). The suggestion is made to use the definition of complex exponentiation to simplify the equation, resulting in y=e0.5t ( i 2 sin (√7/2)t ). It is then noted that since y is always imaginary, only one dimension is needed for the graph. The end result is the graph of y= e^{0.5t}sin((\sqrt{7}/2)t) on the imaginary axis.
dan5
How do you go about sketching y as a function of t for t≥0
I know it goes through the origin, and the gradient is positive here. But I'm unsure on how to deal with the imaginary numbers when I have a graph of y vs t.
Mathematics news on Phys.org
Can you try to simplify it using the definition of complex exponentiation. That is:
[tex]e^{a+ib}=e^a(\cos(b)+i\sin(b))[/tex]
Thanks for that idea, I have done that and am left with
But as I am meant to be plotting y as a function of t, I don't see how the imaginary part will factor in
Well, it will be immediately obvious that no point on the curve will have a real part. So the curve will only move on the imaginary axis.
In general, a function from R to C (real numbers to complex numbers) requires two dimensions for the value as well as one dimension for the argument- in other words, a three dimensional graph! However, as micromass points out, [itex]y= [e^{0.5t}sin(\sqrt{7}{2}t)]i[/itex] is always imaginary so you you really only need a single dimension for that.
Graph [itex]y= e^{0.5t}sin((\sqrt{7}/2)t)[/itex], clearly labeling the "y" axis as imaginary numbers.
FAQ: Sketching exponential curves with complex numbers
What is an exponential curve?
An exponential curve is a mathematical curve that increases or decreases rapidly at a constant rate. It is characterized by the equation y = ab^x, where a and b are constants and x is the variable. Exponential curves are commonly used to model growth or decay in various fields such as finance, biology, and physics.
How do complex numbers relate to exponential curves?
Complex numbers can be used to represent points on an exponential curve. The real part of a complex number represents the x-coordinate and the imaginary part represents the y-coordinate. This allows us to graph and sketch exponential curves in the complex plane.
What are the key features of an exponential curve with complex numbers?
The key features of an exponential curve with complex numbers include its asymptotes, critical points, and behavior at different parts of the complex plane. The asymptotes are the lines that the curve approaches but never touches. The critical points are where the curve changes direction. The behavior of the curve at different parts of the complex plane can be determined by analyzing its real and imaginary parts.
How do you sketch an exponential curve with complex numbers?
To sketch an exponential curve with complex numbers, first determine the values of the constants a and b in the equation y = ab^x. Then, plot a few points on the complex plane by substituting different values of x into the equation. Finally, connect the points with a smooth curve and label the asymptotes, critical points, and other key features.
What are some applications of sketching exponential curves with complex numbers?
Sketching exponential curves with complex numbers is useful in various fields such as physics, engineering, and finance. It can help in modeling and predicting growth or decay in systems and understanding the behavior of complex functions. It is also used in designing and analyzing electrical circuits and in calculating interest rates in finance.
