Skin depth: Same for current as for incoming EM wave?
In summary: This is correct. In the cylindrical case, the current is independent of ##r## since the current is proportional to the surface area of the conductor multiplied by the voltage.
Wminus
173
29
For a good conductor, an incoming plane electromagnetic wave will be attenuated exponentially as it penetrates a distance ##z## into the conductor, ##|\vec{E}(z)| = |\vec{E_0}|e^{-z/ \delta}##. ##\delta## is called the "skin depth". The current generated by this incoming electromagnetic wave is given by ohm's law and thus will be attenuated in the same fashion ##\vec{J_E} = \sigma \vec{E} \Rightarrow |\vec{J_E(z)}| = |\vec{J_{E0}}|e^{-z/ \delta}##.
OK, this is all fair enough. It falls out from maxwell's equations.
However, if you have a cylindrical conductor and you connect it to a high-frequency AC power source, it turns out that that the resulting electrical current ##\vec{J_{AC}}## will have the exact same distribution as ## \vec{J_E}##. Namely, ##\vec{J_{AC}} = \vec{J_{AC0}} e^{-z/ \delta}##, with the exactly same attenuation factor (delta) as before.
Why is this so? Does this mean an AC power source generates a potential difference in the conductor in the same way an incoming electromagnetic wave does?
This is true for a plane wave incident on a plane conductor that occupies the half-space ## z>0##.
I am wondering how you came up with this result, as I think it isn't correct. Qualitatively, would you expect that an AC current in a wire is not a function of ##r##? (Here I am assuming you are using cylindrical coordinates with your conductor along the ##z## axis - it helps us understand if you define your coordinates!).
jason
You're right, sorry about the unclear coordinates. ##z## here is the depth, the distance from the surface to a point radially inside the cylinder, so it's parallel to (cylindrical coordinate) r. It's not the length along the z-axis.
Basically I should've called the "depth" ##d## instead of ##z## to avoid confusion.
Okay - so I understood your coordinates. I am also assuming you are using ##e^{i \omega t} ## time dependence for the rest of this post.
While your formula in the second case is approximately true when the radius of the cylinder is much much larger than the skin depth, it is not true in general. Just like in the planar case, inside your good conductor (which is assumed to satisfy Ohm's law, and for which the displacement current is negligible compared to the conduction current) we have
[tex]
\nabla^2 \mathbf{J} = i \mu \omega \sigma \mathbf{J}
[/tex]
If you solve this in the planar case with the appropriate boundary condition you get your first answer. For the simple cylindrical case, ##\mathbf{J} = \mathbf{\hat{z}}J_z(r) ##, so the equation becomes
[tex]
\frac{1}{r} \frac{\partial}{\partial r}\left(r \frac{\partial J_z}{\partial r} \right) = i \mu \omega \sigma J_z
[/tex]
Solve this with the appropriate boundary conditions and you will get the answer you are looking for. (EDIT: hint: this is a modified Bessel's equation)
jason
Likes Wminus
Related to Skin depth: Same for current as for incoming EM wave?
1. What is skin depth?
Skin depth is a measure of how far an electromagnetic (EM) wave can penetrate into a conducting material. It is the distance at which the amplitude of the wave has decreased to 1/e, or about 37%, of its original value.
2. How is skin depth related to current?
The skin depth for a conducting material is proportional to the square root of the material's electrical conductivity. This means that materials with higher conductivity have smaller skin depths, allowing electromagnetic currents to penetrate more deeply into the material.
3. Is skin depth the same for all EM waves?
No, skin depth varies depending on the frequency of the EM wave. Higher frequency waves have smaller skin depths, meaning they can penetrate less deeply into a material.
4. How is skin depth related to the thickness of a material?
Skin depth is inversely proportional to the thickness of a material. This means that as the thickness of a material increases, the skin depth decreases, and vice versa.
5. Why is skin depth important to consider in electronic devices?
Skin depth is important in electronic devices because it determines how well different materials can conduct or block electromagnetic waves. It is especially important in high frequency applications where the skin depth may be smaller than the thickness of the material, impacting the performance and efficiency of the device.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Classical Physics
  • Electromagnetism
