Skin effect, frequency and heating
In summary: The higher the frequency, the thinner the conductor, and the more heat is generated. Smaller skin depths help to maximize the current density at the surface of the conductor, leading to increased heating.
elcraft
Hi.
I'm trying to understand why smaller skin depths are better for induction heating.
Skin effect means that the highest the frequency is, the thinest the skin depth is (or the depth is simply smaller because of the material). That means the section of the workpiece with electric current in it is smaller, and according to R=ρ*L/S (ρ - electrical resistivity, L - length, S - section area) the resistance is higher, thus heating more.
But if the resistance is higher, the current decreases so that the power remains the same, right? So what makes the difference when the skin depth is changed?
elcraft said:
Hi.
Think of it like this:
The resistance only gets higher because the temperature rises, due to increased current. Yes the current will decrease with increased temperature and resistance, but as soon as this current decreases the temperature decreases and the resistance will follow and the current will once again increase. The temperature will now increase again.
This isn't exactly what is going on but it gives you an idea.
Ok but what difference makes a change in skin depth so that lower skin depths are better for heating?
For a start, higher frequencies with shorter wave lengths will propagate less, in terms of distance than a lower frequency wave. Think of it like this if because higher frequency waves are oscillating more rapidly their energy dissipates sooner, thus they travel less than lower frequency with longer wave lengths.
Knowing this if we consider a high frequency EM wave impinging on the surface of a block of metal, you will see eddy currents form, a number of skin depths deep into the metal. The number of skin depths will depend on the resistivity of the metal block and the frequency of the impinging wave. High resistivity i.e. poorer conductivity means that the current will get attenuated more and as a result the temperature will increase. Yes the current will reduce, but voltages will "build up" because of the "electron pile up" caused by the high resistivitiy due to the temperature increase. As a result the power will remain constant (I*V), and it is the power dissapation that causes the heating effect.
In addition these swirling eddy currents create their own magnetic field that consequently opposes the magnetic field that created it. Thus it effectively acts as an insulator ensuring that the impinging magnetic field does not penetrate deeper and further into the metal and cause eddy currents at greater thicknesses.
With all this current confined to the surface of the metal the current density is much greater at the surface and as a result heating will take place as you have so much current passing through a relatively thin metal conductor.
Hope this helps.
J
Hello,
You are correct in understanding that skin effect is related to the decrease in current as frequency increases, resulting in a smaller skin depth and higher resistance. However, in induction heating, the goal is to transfer heat to the workpiece through the use of induced eddy currents. These eddy currents are generated by the alternating magnetic field produced by the induction coil.
When the skin depth is smaller, the surface area of the workpiece in which the eddy currents are induced is also smaller. This means that the heat is concentrated in a smaller area, resulting in a higher temperature. Additionally, because the current is concentrated in a smaller area, it is able to penetrate deeper into the workpiece, allowing for more efficient heating.
In contrast, a larger skin depth would result in a larger surface area of the workpiece being heated, but at a lower temperature. This is because the induced eddy currents are spread out over a larger area, resulting in a lower concentration of heat.
In summary, smaller skin depths are better for induction heating because they allow for a more concentrated and efficient transfer of heat to the workpiece. I hope this helps clarify the relationship between skin effect, frequency, and heating in induction heating.
Related to Skin effect, frequency and heating
1. What is skin effect?
Skin effect is a phenomenon in which high-frequency alternating current tends to flow near the surface of a conductor, rather than evenly throughout the entire cross-section. This is due to the resistance of the conductor increasing as frequency increases, causing the current to concentrate near the surface where the resistance is lower.
2. How does frequency affect skin effect?
The skin effect is directly proportional to the frequency of the current passing through the conductor. As the frequency increases, the skin depth (the depth at which the current is concentrated) decreases, resulting in higher resistance and more heating in the surface layers of the conductor.
3. Why is skin effect important?
Skin effect is important because it can cause significant heating in conductors, which can lead to energy loss and potential damage to equipment. It is also a consideration in the design and construction of high-frequency transmission lines and antennas.
4. How is skin effect mitigated?
There are several ways to reduce the effects of skin effect, including using conductors with larger surface area, such as stranded wire, and using hollow or flat conductors. Another method is to use a skin effect reduction technique, such as litz wire, which is made up of multiple strands insulated from each other.
5. Does skin effect only occur in AC circuits?
While skin effect is most commonly observed in AC circuits, it can also occur in DC circuits at high frequencies. However, the effect is much smaller in DC circuits due to the absence of alternating current and the resulting constant distribution of current throughout the conductor.
  • Electrical Engineering
  • Electromagnetism
