Skydiving: Falling 1.2 km at 9.8 m/s^2
  • Thread starter ADH
  • Tags
    Falling
In summary, the conversation is about a person going skydiving and the discussion of how fast they are going when they fall a height of 1.2 kilometers. There are multiple suggestions given, such as using conservation of energy, kinematics, or considering terminal velocity. The original poster is looking for a solution to their problem and is seeking help from others in the forum. Some members are hesitant to give direct answers and instead offer hints or different approaches to solving the problem.
ADH
A person goes skydiving. The plane is one kilometer up and they decide to fall a height of 1.2 kilometeres before opening their chutes. How fast are they going at that point?
Isn't it 9.8 m/s^2 because gravity has to be dragging them down at that rate?
Thank you!
They will be accelerating at that rate, but that will not be how fast they are going. To get how fast, you need to find the velocity at that point.
Conservation of energy will solve this quickly :wink:
So velocity is distance / time. I have the distance, but don't have the time. How am I supposed to solve for velocity then?
Um. Why do they open their parachutes after falling 1.2km when they are only 1.0km high?
I meant 1/2. That's what the title says. I made a mistake in the description.
99 percent of terminal velocity, with prone attitude, for a typical body type takes about 550 metres. 90% of terminal velocity happens after falling about 375 metres.
Consider the energy before and the energy after.
Conservation of energy: KE+PE = constant.
As for the why the parachute is opened, I am not sure about the height they have to open their chutes at, but if they open it without reaching terminal velocity, then bad things happen.
Why are you ignoring air friction, rock.freak. Skydivers don't fall in a vacuum.
This is probably a few weeks into an intro physics course, chill out. You got to walk before you can run.
For two reasons, one what Pengwuino said and two, had air resistance been included, more information would need to be given I believe.
I believe it is like this:
Vi=0m/s a=9.8m/s^2 d=500m Vf=?
So we use this formula:
Vf^2= Vi^2 + 2ad
Once you plug in the numbers and calculate, it should come out to 99 m/s
However, I just started learning Physics yesterday, so do not take my word for it.
Thanks OThePestO.
But really, this is a Physics forum. How is it that nobody knows the answer? This is a basic physics question, it doesn't involve extremely complicated calculation yet.
Its a simple kinematic problem: don't listen to the others about conservation of energy and drag, because you have not learned that yet.
y = (vi)t - (1/2)gt^2
since vi = 0; your jumping out of a plane you get
y = -(1/2)gt^2set y to 500m (1/2 km) and solve for the time. Once you have time you can plug it in a kinematic equation to find the velocity.
Velocity is the derivative of position (assuming your class is calculus based)
v = dy/dt = -(gt)
plug n solve
ADH said:
Thanks OThePestO.
Do you have an answer to reference with? If no one else provides a better solution, I would just go with mine, assuming this is for marks. What are the current formulas you are working with, as I assume you would be required to show how you came to use the formula I provided if you had not yet learned it.
ADH said:
Thanks OThePestO.
We are forbidden to give you the answer. We can help you arrive at the correct answer.
Also, there was a template you were given in which you were supposed to supply the question. You deleted it.
Yeah, but I can't agree. If professors will say what they mean and mean what they say...
Or maybe you're wrong and this is all about terminal velocity for the bright students. Let me consult my Ouji board...
Not enough information is given in the question to utilize finding the terminal velocity.
The template was terrible. It was much easier to just write my question. You're not allowed to give answers on this forum? Is that a joke? If I've been working hard on a problem, and all of the help isn't helping, it would help much more to give me the answer so I would have something to work towards.
Thus far, I see that three replies were given that would attempt to aid you, but since they all have differing things which depend on what you've learned, it is hard to say.
They were
Conservation of Energy
Using kinematics
Terminal velocity
Which one have you learned in your class?
Also, you didn't really post what you attempted, so we don't really know along what lines you tried which is why everyone has a differing input.
Look at my post, follow the steps and you will arrive at the correct answers.
why would they have terminal velocity either. That is at least mechanics 1 and this seems like grade 10 physics
FAQ: Skydiving: Falling 1.2 km at 9.8 m/s^2
What is the speed of falling while skydiving from a height of 1.2 km?
The speed of falling while skydiving from a height of 1.2 km is approximately 9.8 m/s^2. This is due to the force of gravity pulling the skydiver towards the ground at a constant rate.
How long does it take to reach the ground while skydiving from a height of 1.2 km?
The time it takes to reach the ground while skydiving from a height of 1.2 km depends on the air resistance and the weight of the skydiver. On average, it takes around 10-12 seconds to reach the ground at a speed of 9.8 m/s^2.
What factors affect the speed of falling while skydiving?
The speed of falling while skydiving is affected by several factors, including the air resistance, the weight of the skydiver, the height from which they are jumping, and the position of their body during the fall.
Is it safe to skydive from a height of 1.2 km?
Skydiving from a height of 1.2 km can be safe if proper safety measures are taken, such as wearing a parachute and following all safety protocols. However, it is important to note that there is always a risk involved in any extreme sport.
Can the speed of falling while skydiving be controlled?
Yes, the speed of falling while skydiving can be controlled to some extent by changing the body position and using the parachute. By spreading out their arms and legs, the skydiver can increase the air resistance and slow down their fall. Deploying the parachute also allows for a controlled and slower descent to the ground.
