Slab on a Brick wall (Only 3 columns)
In summary, the conversation discusses the possibility of constructing a roof on a 3 story building with a brick wall at the 2nd floor. The dimensions of the brick wall are 8' x 14' and the individual is seeking advice on the best way to do so. However, it is advised that they consult a licensed engineer and follow local building codes for safety reasons.
Prasad2007
I have a 3 story building.
Will it be possible to put a slab (to make it a roof top) on a brick wall at 2nd floor?
It was designed to construct a roof.
Dimensions of brick wall: 8' X 14'
Or please suggest me the best way to make a roof top on it.
You do not have the skills or knowledge to be doing any construction design. You need to contract with a licensed engineer to do the plans and get them approved by your local building inspection department.
Please stop posting like this here -- asking for advice on how to bypass your local building codes. It is just too dangerous in your case.
Related to Slab on a Brick wall (Only 3 columns)
1. What is a slab on a brick wall?
A slab on a brick wall is a type of foundation where a concrete slab is poured on top of a row of bricks that serve as a support for the structure above. This method is commonly used in low-rise buildings with only three columns, as it is a cost-effective and efficient way to provide a stable base for the structure.
2. How is the slab on a brick wall constructed?
The construction of a slab on a brick wall starts with digging trenches and pouring a concrete footing around the perimeter of the building. Then, a layer of compacted gravel is added, followed by a layer of sand. The bricks are laid on top of the sand and leveled, and then a reinforced concrete slab is poured on top of the bricks. The slab is typically at least 4 inches thick and is reinforced with steel bars to ensure its strength and stability.
3. What are the advantages of using a slab on a brick wall foundation?
One of the main advantages of using a slab on a brick wall foundation is its cost-effectiveness. It requires less excavation and materials compared to other types of foundations. It also allows for a faster construction process, as the bricks can serve as both the foundation and the walls of the building. Additionally, the slab on a brick wall foundation is suitable for a variety of soil types and can withstand heavy loads.
4. What are the potential drawbacks of a slab on a brick wall foundation?
One potential drawback of a slab on a brick wall foundation is that it is not suitable for areas with high water tables or areas prone to flooding. The slab can be affected by shifting soil or water pressure, leading to cracks or other damage. Additionally, this type of foundation may not be suitable for larger, multi-story buildings, as it may not provide enough support for the structure.
5. How can I ensure the stability of a slab on a brick wall foundation?
To ensure the stability of a slab on a brick wall foundation, it is essential to follow proper construction techniques and use high-quality materials. The bricks should be laid evenly and level, and the concrete slab should be properly reinforced with steel bars. It is also important to conduct regular inspections and address any issues, such as cracks or settlement, as soon as they are identified.
  • General Engineering
9K
