Slew-rate of Op Amps in practice
In summary, the conversation discusses a discrepancy between the specified slew-rate value for an op-amp on a data sheet and the actual measured value using a step-input. The speaker explains that the maximum slew-rate was supposed to be 1V/us, but they found it to be only 0.4V/us. They also mention that the slew-rate can be affected by the circuit configuration, power supply voltages, and output loading.
NewtonianAlch
453
We have a given op-amp, the data sheet has a specified slew-rate value for it, but in practice it happens to be a lot lower.
I essentially used a step-input to determine the slew-rate and found it to be much lower. I can't remember the exact values now. I think The maximum slew-rate was 1V/us, but I calculated it based on the square wave input (step) to be like 0.4V/us, why would this be?
Thanks
What its the slew rate of your step input generator?
Slew rate is also a function of circuit configuration, in particular the power supply voltages and output loading, especially if capacitive.
Related to Slew-rate of Op Amps in practice
1. What is slew rate and why is it important in op amps?
Slew rate is the maximum rate of change of output voltage in an op amp. It is important because it determines the maximum frequency at which an op amp can accurately reproduce a signal. If the input signal has a higher frequency than the slew rate, the op amp will not be able to keep up and the output signal will be distorted.
2. How is slew rate measured in op amps?
Slew rate is typically measured in volts per microsecond (V/μs). It can be measured by applying a step input voltage to the op amp and measuring the time it takes for the output to reach its final value. The slew rate is then calculated by dividing the change in output voltage by the time it took to change.
3. What factors can affect the slew rate of an op amp?
The slew rate of an op amp can be affected by the internal circuitry of the op amp, the load on the output, and the power supply voltage. Additionally, external components such as capacitors and resistors can also impact the slew rate.
4. How does slew rate affect the overall performance of an op amp?
The slew rate of an op amp is an important factor in determining its bandwidth and frequency response. If the slew rate is too low, the op amp will not be able to accurately amplify high frequency signals. It can also cause distortion in the output signal.
5. Can the slew rate of an op amp be increased?
Yes, there are a few ways to increase the slew rate of an op amp. One way is to use a higher power supply voltage. Another way is to use op amps with a higher slew rate specification. Additionally, external components such as bypass capacitors can be used to improve the slew rate. However, it is important to note that increasing the slew rate may also introduce other performance trade-offs, such as increased noise or reduced stability.
