Slight Computation Error? Not sure what I'm doing wrong
In summary: would be an example of a point of inflection, because the curve changes its concavity from concave up to concave down.
SnakeDoc
27
Water is poured into a container that has a leak. The mass m of the water is given as a function of time t by m = 4.9t.8 - 3.0t + 21, with t ≥ 0, m in grams, and t in seconds.(a) At what time is the water mass greatest, and (b) what is that greatest mass? What is the rate of mass change at (c) t = 2.4 s and (d) t = 5.4 s?
I know that part c and d have to kg/min
m=4.9t.8-3.0t+21
d/dm =3.92t-.2-3.0
I got part (a) correct as 3.80911 by finding the points of inflection from the derivatives and then looking at where the equation changes from positive to negative. Part (b) was also easy because all I had to do is plug my answer into the original equation and I got 23.8568361. It's part (c) and (d) that I'm having trouble with.
For part (c) and (d) I know I have to take the derivative so I did and got
3.92t-.2 - 3.0 then I plug in
3.92(2.4)-.2 - 3.0=.2903630437g and 3.92(5.4)^(-.2) - 3.0= -.2022602387g
m=4.9t.8-3.0t+21
d/dm =3.92t-.2-3.0
You mean ##\frac{dm}{dt}##.
The numbers are correct for your calculations. I notice that ##m## is given in grams and ##t## in seconds, but for parts c and d you are asking for kg/min. Is the problem correctly stated and, if so, you need to account for the units changes.
That's not what you mean. You will have found the extrema, by looking for where the first derivative vanishes. A point of inflection is where the second derivative is zero.
Not necessarily. A counterexample is y = x1/3. y' is undefined at x = 0, as is y'', but the curvature changes from concave up for x < 0 to concave down for x > 0, and the function is defined at x = 0.
Maybe there are different definitions around. E.g. http://en.wikipedia.org/wiki/Inflection_point#Functions_with_discontinuities says a point of inflection has a zero second derivative, but that not all curvature reversals are points of inflection.
I don't see what you're saying in the link you provided. The section titled "Functions with discontinuities" says this:
Some functions change concavity without having points of inflection. Instead, they can change concavity around vertical asymptotes or discontinuities. Take, for example, the function 2x2/(x2 – 1). It is concave when |x| > 1 and convex when |x| < 1. However, it has no points of inflection because 1 and -1 are not in the domain of the function.
Were you referring to some other section in this page?
One of the calculus books I have (Calculus and Analytic Geometry, 2nd Ed., Abraham Schwartz) has this definition for inflection point (p. 240):
The point P is a point of inflection of curve C if C faces in one direction in a region immediately to the left of P, and in the opposite direction in a region immediately to the right of P.
From this definition, the point (0, 0) on the curve y = x1/3 is an inflection point, even though y'' is not zero at the origin (or even defined there).
It says "Instead, they can change concavity around vertical asymptotes". Your ##x^{\frac 13}## exemplifies that. Note the 'instead', implying a vertical asymptote does not count as a point of inflection.
I should also have referenced this further up the same page:
If x is an inflection point for f then the second derivative, f″(x), is equal to zero if it exists,​
Now, that wording is a little odd, but since it is under the heading "A necessary but not sufficient condition", it looks like it means
If x is an inflection point for f then the second derivative, f″(x), exists and is equal to zero​
It certainly should not be taken to mean the second derivative need not exist since for sufficiency it goes on to say
One also needs the lowest-order (above the second) non-zero derivative to be of odd order​
Having said all that, I have to agree that defining inflection points in terms of curvature reversal, (or, equivalently, a change of sign of the second derivative), regardless of whether the sign change is through zero or via infinity, seems a more natural definition.
I don't find it at all surprising that some authorities define it one way, some another.
The graph of y = x1/3 has no vertical asymptotes. The tangent to the curve at (0, 0) is vertical, but ##\lim_{x \to 0} x^{1/3}## exists and is equal to 0, so there is no asymptote when x = 0.
The function I gave as an example fits this pattern. We do have an inflection point at (0, 0), but neither f' nor f'' exists.
No, that's not what this is saying. Rather, it's saying that for an inflection point at x = a, if f'' exists, then it must be true that f''(a) = 0. However, we can have an inflection point without f'' existing at the point, as in my example.
It doesn't say that. It might be what's meant but it is not what it says. It leaves it quite unclear as to what the test is when the second derivative does not exist. Further, in the sufficiency clause, it requires the existence of some higher order derivative.
You're right that I should not have described your ##x^{\frac 13}## as having a vertical asymptote, I should have said discontinuity, which is the other case dealt with in the same clause. So it still appears that that reference defines it as a curvature reversal but not a point of inflection.
I followed a few more links:
http://mathworld.wolfram.com/InflectionPoint.html
A necessary condition for
to be an inflection point is [PLAIN]http://mathworld.wolfram.com/images/equations/InflectionPoint/Inline5.gif.
A sufficient condition requires
and
to have opposite signs in the neighborhood of [PLAIN]http://mathworld.wolfram.com/images/equations/InflectionPoint/Inline8.gif[/INDENT]
(Intriguing: a sufficient condition that fails to imply a necessary condition!)
http://sydney.edu.au/stuserv/documents/maths_learning_centre/thesecondderivative.pdf
A point of inflection occurs at a point where d2y/dx2=0 AND there is a change in concavity of the curve at that point.​
http://clas.sa.ucsb.edu/staff/lee/inflection points.htm
the second derivative must equal zero at that point.
I only found one which supports the other view:
http://www.sosmath.com/calculus/diff/der15/der15.html
[PLAIN]http://www.sosmath.com/calculus/diff/der15/img4.gif[/INDENT]
Having researched all that, I conclude that your definition is surely the right one, but most web pages get it wrong.
Thanks for drawing attention to it.​
I hope that you're referring to the first derivative being is discontinuous, because y = x1/3 is continuous everywhere.
I found the links you posted to be interesting. The textbooks I used when I was teaching calculus all used definitions similar to the one I posted from Schwartz; i.e., that it wasn't necessary for f'' to be zero in order for an inflection point to be present.
FAQ: Slight Computation Error? Not sure what I'm doing wrong
What is a slight computation error?
A slight computation error is a mistake made in a mathematical or computational calculation that results in a small deviation from the expected or accurate answer. It can be caused by a variety of factors, such as human error, rounding errors, or faulty algorithms.
How do I know if I have a slight computation error?
You can identify a slight computation error by comparing your calculated result to the expected or accurate answer. If there is a small discrepancy, it is likely due to a slight computation error.
What could be causing my slight computation error?
There are many potential causes of a slight computation error, including incorrect data input, rounding errors, faulty formulas or algorithms, or even hardware or software malfunctions. It is important to carefully review your calculations and check for any potential sources of error.
How can I fix a slight computation error?
The best way to fix a slight computation error is to carefully review your calculations and identify the source of the error. If it is due to incorrect data input, make sure to correct the data. If it is due to a faulty formula or algorithm, try using a different calculation method. If the error persists, seek assistance from a colleague or consult relevant resources.
How can I prevent slight computation errors in the future?
To prevent slight computation errors, it is important to double-check your calculations, use accurate and precise data, and verify the accuracy of your formulas and algorithms. It can also be helpful to use multiple methods of calculation and seek assistance from others when needed. Additionally, regularly updating and maintaining your hardware and software can help prevent potential malfunctions that may lead to computation errors.
