Slip rings, commutator, dc motor
In summary, slip rings are more robust and can operate at higher speeds than commutators because the brushes do not disconnect from one polarity and reconnect to the other polarity repeatedly.
Salvador
505
70
If I'm not mistaking , all DC and also universal motors have a brushed commutator not a slip ring commutator because the rotor wires need to keep the same current direction as they rotate pass the same magnetic stator pole.
so the only DC motor which could operate on slip rings is a homopolar motor since the current doesn't need to change direction ?
now in terms of wear and robustness , do slip rings have a longer life and can work at higher speeds than a commuttator , is it because a slip ring is made out of one piece with no slots and so the brush ravels smoother along its surface with less friction?
also i suppose in slip rings there is much less arcing than in commutators beacuse the current isn't switching ?
Likes Alfredo722
Salvador said:
i suppose in slip rings there is much less arcing than in commutators because the current isn't switching ?
In AC the current switches so the brushes maintain contact, in DC the brushes disconnect from one polarity and reconnect to the other polarity repeatedly which does cause more wear from arcing.
I can't quite agree , even with AC fed universal motor the commutator still switches the current , because many universal motors running on AC spin up to very high rpm much faster than an induction motor could on the AC frequency due to the fact that an induction motor is frequency locked but in the universal motor the rotor at very high rpm , a single half period of an 50hz ac wave can be long enough so that more than one commutator slot has passed the brush and that means that say for example 2 or more commutator slots pass the same brush before the AC current has changed direction into the other half period which again at very high rpm can last long enough for multiple slots to pass a single brush which would indicate that the commutator still does the switching even with AC in a universal motor, I would be happy if someone here could elaborate or confirm.
thanks.
Related to Slip rings, commutator, dc motor
1. What is a slip ring and what is its function?
A slip ring is an electrical connector that allows the transmission of power and signals between a stationary and a rotating part. It consists of a stationary metal ring and a rotating metal brush. The function of a slip ring is to provide a continuous connection between a power source and a rotating component, allowing for the transfer of electricity, signals, and data without interruption.
2. What is a commutator and how does it work?
A commutator is a mechanical switch that is used to reverse the direction of electrical current in a DC motor. It is made up of copper segments attached to the armature of the motor and connected to the power source through carbon brushes. As the armature rotates, the commutator switches the direction of the current flow, allowing the motor to continue rotating in the same direction.
3. What is the difference between a slip ring and a commutator?
A slip ring is used in AC (alternating current) systems to transfer power and signals between a stationary and a rotating part, while a commutator is used in DC (direct current) systems to reverse the direction of current flow in a motor. Additionally, a slip ring is made up of a stationary ring and a rotating brush, while a commutator is made up of copper segments attached to the armature of a motor.
4. How does a DC motor work?
A DC motor works by converting electrical energy into mechanical energy. When a current is applied to the motor, it creates a magnetic field that interacts with the permanent magnets inside the motor, causing the armature to rotate. The commutator and brushes then switch the direction of the current flow every half rotation, allowing the motor to continue rotating in the same direction.
5. What are the applications of slip rings, commutators, and DC motors?
Slip rings, commutators, and DC motors have a wide range of applications in various industries. Some common applications include electric vehicles, industrial machinery, robotics, and household appliances such as fans and blenders. They are also used in wind turbines, elevators, and in many other devices that require controlled and continuous rotation.
  • Electrical Engineering
14K
