rootbarb
- 4
The function that passes through (8,3) and every time x increases by 1 unit, the fuction decreases by 7 units
The slope of y=-7 is a constant value of -7. This means that for every increase of 1 in the x-coordinate, the y-coordinate will decrease by 7.
A negative slope indicates a downward trend or decrease in the dependent variable (y) as the independent variable (x) increases. In this case, y decreases by 7 for every increase of 1 in x.
When x increases from 8 to infinity, it means that the x-coordinate is continuously getting larger and larger without any limit. This also means that the slope of y=-7 will remain constant at -7.
To graph y=-7 as x increases from 8 to infinity, plot a point at (8,-7) on the coordinate plane and draw a straight line that extends infinitely in the negative y-direction. This line will have a slope of -7 and will never touch the y-axis.
The slope of y=-7 is significant because it represents the rate of change or the steepness of the line. In this case, the slope of -7 means that for every increase of 1 in x, y decreases by 7. It also helps us understand the relationship between the independent and dependent variables in the equation.
