Smallest Distance $P(-8,4)$ to Line $y=6x$ at Origin
In summary, the smallest distance between point P(-8,4) and the line L through the origin, with equation y=6x, is approximately 8.54 units. This can be found by using the formula d=|Am+Bn+C|/sqrt(A^2+B^2), where A=6, B=-1, m=-8, and n=4. The square of the distance is given by the equation D^2=(x+8)^2+(6x-4)^2, and the critical value is x=16/37. Plugging this value into the formula, we get a minimum distance of 52/sqrt(37). This matches the given answer of approximately 8.
karush
MHB
3,269
$\tiny{231.12.3.63}$
$\textsf{ Determine the smallest distance between point P and the line L through the origin}\\$
$\textsf{$P(-8,4)$ L is $y=6x$ }$ \\
$\textsf{$\therefore A=6, B=-1, m=-8, n=4$}$
\begin{align*}\displaystyle
d&=\frac{|Am+Bn+C|}{\sqrt{A^2+B^2}}\\
&=\frac{|(6)(-8)+(-1)(4)|}{\sqrt{36+1}} \\
&=\frac{52}{\sqrt{37}}\approx8.54
\end{align*}
$\textit{Demos indicated that the answwer to this was $\approx8.43 $ so ?}\\$
$\textit{also, was going to try to solve this with a vector but couldn't seem to to set it up...}$
The square of the distance is:
\(\displaystyle D^2=(x+8)^2+(6x-4)^2=37x^2-32x+80\)
Critical value is from:
\(\displaystyle 74x-32=0\implies x=\frac{16}{37}\)
\(\displaystyle D_{\min}=\frac{52}{\sqrt{37}}\)
Just as you found. :D
thanks... wouldn't have thot of that
nice thing about MHB...:cool:
FAQ: Smallest Distance $P(-8,4)$ to Line $y=6x$ at Origin
What does the "smallest distance" refer to in this context?
The smallest distance refers to the shortest distance between a given point and a given line. In this case, the given point is $P(-8,4)$ and the given line is $y=6x$.
How is the smallest distance calculated in this scenario?
The smallest distance from a point to a line can be found by using the formula: d = |Ax + By + C| / √(A^2 + B^2), where A, B, and C are the coefficients of the line's equation and x and y are the coordinates of the given point.
Why is the smallest distance to the line at the origin important?
The smallest distance to the line at the origin can be important in various scientific and mathematical applications, such as finding the shortest distance between two objects in space or optimizing the placement of objects in a given space.
Can the smallest distance be negative?
No, the smallest distance cannot be negative. The absolute value in the formula ensures that the distance is always positive.
What is the significance of the given point being (-8,4)?
The given point (-8,4) represents a specific point in the coordinate plane, and the smallest distance to the line at the origin is unique for this point. Changing the coordinates of the point would result in a different smallest distance to the line.
