Smallest infinity for Euclidean geometry to work
In summary, the conversation discusses the need for a denser point arrangement than rational numbers in order to ensure continuity in Euclidean geometry. The concept of earlier infinity is mentioned, which points to the continuum hypothesis. The use of algebraic numbers as points in geometry is also discussed, as well as the limitation of computable numbers in representing certain geometric values. The concept of non-computable numbers is introduced, with an example being Chaitin's constant.
Ahmed Abdullah
203
If we choose rational numbers to represent points on a line then there will be gaps on the line and consequently the plane will be full of holes. Then we cannot say that two non-parallel line must intersect on a point (because they may meet at the gaps). So obviously we need point arranged more densely than rational number. I was wondering do we necessarily need real number line for euclidean geometry or we can stop at earlier infinity. After writing this far I realize it points to continuum hypothesis. But I don't know enough and will highly appreciate your input and comment.
I am not a student of mathematics but dabble with its concept every now and then.
Mathematics news on Phys.org
What do you mean by "earlier infinity?"
Now I understand i was looking for infinity that is bigger than infinity associated with rational number but smaller than that of real number. I know that it is undecidable.
But i was originally wondering what kind of infinity is necessary for continuity in the sense of euclidean geometry.
A countable set should suffice. Model the "points" in plane geometry as ordered pairs of algebraic numbers. Then two lines defined by two pairs of "points" will always have a "point" at which they intersect.
Likes Ahmed Abdullah
Seems to me you do need to the full set. If all you care about are lines, then you'll only need the rational numbers since if you restrict the coefficients of a line, [itex] y = ax+b[/itex] to rational numbers, you'll always get a rational solution for the intersection of two lines.
However, what happens when I want to know the length of the diagonal of a square of side length 1? The answer is [itex] \sqrt{2}[/itex]. What about the circumference of a circle of radius 1? The answer is [itex]2\pi[/itex].
You quickly move from rational numbers to irrational as you start looking at polygons, and then quickly to transcendental when you start looking at curves.
Even if you start looking at curve lengths, that won't take you past the computable numbers. Those are still countable.
Thank you for your response. I understand your point about algebraic number. If points of the plane is defined by pair of algebraic number, then the intersection of any two lines will also be a point (I get it). But i don't get your last response about computable number. I'll really appreciate if you elaborate the point.
Computable numbers, http://en.wikipedia.org/wiki/Computable_number, are numbers that can be calculated to any desired precision by a fixed and finite program. Since there are at most countably many programs, there are at most countably many computable numbers.
The value of a trigonometric function or inverse trigonometric function evaluated at a computable number is, if defined at all, computable. The length of a circular arc with a computable radius between two computable endpoints is, therefore, computable.
What are some examples of non-computable numbers?
It is impossible to explicitly display a non-computable number. It is impossible to even present an algorithm that could produce one. After all, if such an algorithm existed, the number would have to be computable.
One can nonetheless write down a definition for a non-computable number. For instance, http://en.wikipedia.org/wiki/Chaitin's_constant
Related to Smallest infinity for Euclidean geometry to work
1. What is the Smallest Infinity for Euclidean Geometry to Work?
The smallest infinity for Euclidean geometry to work is known as the countable infinity, also known as aleph-null or ℵ0. This is the infinity of the set of all natural numbers (1, 2, 3, 4, ...).
2. Why is ℵ0 the Smallest Infinity for Euclidean Geometry to Work?
Euclidean geometry is based on the concept of points, lines, and planes, which are all considered discrete and countable. As ℵ0 represents the smallest infinity of countable objects, it is the most suitable for Euclidean geometry.
3. Can Euclidean Geometry Work with Larger Infinities?
No, Euclidean geometry is limited to the countable infinity of ℵ0. This is because the axioms and principles of Euclidean geometry are based on finite and countable elements, and cannot be applied to larger infinities.
4. How is ℵ0 Related to Other Infinities in Mathematics?
ℵ0 is the smallest infinity in mathematics and is considered the starting point for larger infinities. It is also closely related to the concept of cardinality, which measures the size of a set. All countable sets have the same cardinality as ℵ0.
5. Are There Practical Applications of the Smallest Infinity in Euclidean Geometry?
While ℵ0 is primarily a theoretical concept, it has practical applications in computer science and information theory. It is used to represent the infinite number of possible inputs and outputs in a computer program, and in the study of algorithms and data structures.
  • General Math
  • General Math
