Smallest Number in Set A and Proving It Is Not the Only Member
  • MHB
  • Thread starter anemone
  • Tags
    Member Set
In summary, the smallest number in a set is the number with the lowest value compared to all other numbers in the set. This can be determined by comparing all the numbers in the set and finding the one with the lowest value, either by arranging them in ascending order or using mathematical operations. To prove that a number is the smallest in a set, evidence such as mathematical calculations or logical reasoning can be used. The smallest number in a set is not always unique, as there can be ties between two or more numbers with the same value. Therefore, there can be multiple smallest numbers in a set.
anemone
MHB
POTW Director
3,883
115
Let $A$ be the set of all positive integers $a$ such that $2^{2008}+2^a+1$ is a square. Find the smallest number of $A$ and prove that it is not the only member of $A$.
Mathematics news on Phys.org
My solution:
Let \(\displaystyle b=2^{2008}+2^a+1\)
i) If $a=1005$, then we may write:
\(\displaystyle b=\left(2^{1004}+1\right)^2\)
ii) If $a=4014$, then we may write:
\(\displaystyle b=\left(2^{2007}+1\right)^2\)
Very well done, MarkFL!
Aren't you my smart admin? Hehehe...
FAQ: Smallest Number in Set A and Proving It Is Not the Only Member
What is the smallest number in a set?
The smallest number in a set is the number that has the lowest value compared to all the other numbers in the set.
How do you determine the smallest number in a set?
To determine the smallest number in a set, you would need to compare all the numbers in the set and find the one with the lowest value. This can be done by arranging the numbers in ascending order or by using mathematical operations such as finding the minimum value.
How can you prove that a number is the smallest in a set?
To prove that a number is the smallest in a set, you would need to show that it has the lowest value when compared to all the other numbers in the set. This can be done by providing evidence such as mathematical calculations or by using logical reasoning.
Is the smallest number in a set always unique?
No, the smallest number in a set is not always unique. It is possible for two or more numbers in a set to have the same value, making them tied for the smallest number in the set.
Can there be multiple smallest numbers in a set?
Yes, if two or more numbers in a set have the same value and are the lowest among all the numbers in the set, they can all be considered as the smallest numbers in the set. In this case, there would be multiple smallest numbers in the set.
