Smallest possible orbit and velocity of a particle?
In summary, there are restrictions on the smallest possible radius of an orbit of a given mass, but once the distance becomes small enough, classical mechanics can no longer be applied and quantum mechanics must be used. Therefore, the result obtained using a mixture of relativity and quantum mechanics is not valid.
jamie.j1989
79
If the units of angular momentum are quantised in integer amounts of ##\hbar##, does that then imply that we have restrictions on the smallest possible radius ##r## of an orbit of a given mass ##m##, given that the speed of light is ##c##. As follows,
$$\hbar=m\bf{r}\times \bf{v}$$, where v is the velocity of the particle of mass m, if the velocity vector and radius are perpendicular then we have,
$$\frac{\hbar}{rm}=v$$
and if we account for relativity, we have
$$\frac{mv}{\sqrt{1-\frac{v^2}{c^2}}}=\frac{\hbar}{r}$$
If we now take the minimum radius to be the plank length l, we have for the maximum velocity of a particle with the minimum orbital angular momentum
$$v=c\sqrt{\frac{\frac{\hbar^2}{l^2}}{\frac{\hbar^2}{l^2}+m^2c^2}}$$
Which always gives v<c, which makes sense but I'm not sure if this result is correct?
Relativity and quantum mechanics are not fully compatible, so one can expect to run into problems when one tries to do a calculation involving both for very very small, close objects.
I think once the distance between an 'orbiting' and an 'orbited' object becomes small enough, one would have to analyse it using pure quantum mechanics, not a mixture of that and relativity. The QM derivation of the orbitals of a hydrogen atom is an example of that.
It's not meaningful because quantum objects don't have classical orbits.
Related to Smallest possible orbit and velocity of a particle?
1. What is the smallest possible orbit for a particle?
The smallest possible orbit for a particle is called the Bohr radius, which is the smallest stable orbit for an electron around a hydrogen nucleus. It is approximately 0.053 nanometers.
2. Can a particle have a velocity of zero in its orbit?
No, according to the laws of quantum mechanics, a particle must always have a non-zero velocity in its orbit to prevent it from collapsing into the nucleus.
3. How is the velocity of a particle in its orbit determined?
The velocity of a particle in its orbit is determined by its angular momentum, which is a product of its mass, velocity, and distance from the center of the orbit.
4. Can the smallest possible orbit and velocity of a particle be observed?
Yes, the smallest possible orbit and velocity of a particle can be observed using advanced technologies such as electron microscopes and particle accelerators.
5. Are the smallest possible orbit and velocity of a particle constant?
No, the smallest possible orbit and velocity of a particle can vary depending on the specific conditions such as the type of particle and the presence of external forces.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
