{Sn} is convergent -> {|Sn|} is convergent
  • Thread starter Thread starter Jamin2112
    Convergent
If the sequence {sn} converges to a limit s, then the sequence {|sn|} must also converge. The proof involves showing that if {|sn|} does not converge, then {sn} cannot converge either. Utilizing the triangle inequality is key, specifically demonstrating that the difference between |sn| and s can be bounded by the difference between sn and s. The discussion also touches on a related problem regarding Cauchy sequences and convergence of subsequences, emphasizing the importance of contradiction in proofs. The overall focus is on establishing the convergence of the absolute value of a convergent sequence.
Jamin2112
{Sn} is convergent ---> {|Sn|} is convergent
I need to prove that if {sn} is convergent, then {|sn|} is convergent.
sn is convergent if for some s and all ε > 0 there exists a positive integer N such that |sn - s| < ε whenever nN.
Proof. By contrapositive. Suppose {|sn|} is not convergent. Then for all s there exists an ε > 0 such that ||sn| - s|| ≥ ε for all n.
... I need to somehow show that this implies that {sn} does not converge.
Maybe some fancy triangle inequality thing like
ε ≤ ||sn| - s| ≤ ||sn| - sn| + |sn - s|
Wat do, PF?
Ah, wait. I think I figured out something.
ε ≤ ||sn| - s| ≤ ||sn| - sn| + |sn - s| ≤ 2|sn| + |sn - s|
Am I any closer?
You are supposed to show that |Sn| converges to |S| not to S.
The trick is to show that ||Sn|-|S|| <= |Sn-S|
Hint to showing it:
|S| = |Sn + (S-Sn)|
And use the triangle inequality.
Hint to showing it:
|S| = |Sn + (S-Sn)|
I knew the triangle inequality would show his face somewhere.
http://images.icanhascheezburger.com/completestore/2009/3/5/128807888821558038.jpg
Hey, I need a hint for another problem. (You guys give stellar hints. Pat yourselves on the back.)
Suppose {pn} is a Cauchy sequence in a metric space X, and some subsequence {pni} converges to a point p in X. Prove that the full sequence {pn} converges to p.
As always, I'd love to use contradiction.
Suppose {pn} does not converge to p. Then for some ε > 0, d(p,pn) ≥ ε for all n. Then d(pm,pn)+d(pm,p) ≥ ε for all m, n. But {pm} is a Cauchy sequence, so with the proper choice of m, n we'll have d(pm,pn) < ε. ... blah blah I hope this is going somewhere. A little hint, maybe?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
