Snell's Window fisherman problem TIRF
  • Thread starter muddyjch
  • Tags
    Window
In summary: If \theta2 is smaller, then the fish can see the fisherman. If \theta1 is smaller, then the fisherman can see the fish.In summary, for the fish to be able to see the fisherman, the angle of refraction (\theta2) must be smaller than the angle of incidence (\theta1). This means that the fisherman must be at a shallower angle from the fish's perspective. Whether or not the fisherman can see the fish depends on the specific values of \theta1 and \theta2, which can be calculated using the equations and methods described above.
muddyjch
For a swimmer or fi sh, it appears that light from above the surface enters only through a circle, defi ned by an angle , theta as shown below:(See Diagram)
For the following, assume that the refractive index of water is 1.33 and that of air is 1.0.
(a) Suppose that the fi sh in the drawing above is 2m below the surface of a lake and is
looking upward. What is the angle de fining the apparent window? (You must show
how to calculate this angle, not just look it up!)
(b) What is the diameter of the window the fish sees?
(c) Suppose that the fi sh is 6m from the bank of the lake, and there is a fi sherman standing on the bank. Will the fi sh be able to see the fi sherman? Will the fi sherman be able to see the fish? Explain your answer with appropriate drawings and calculations.
[tex]\theta[/tex]c=arcsin(n1/n2)
For part a I got arcsin(1.00/1.33)=48.75 degrees. If you multiply by 2 that gives you [tex]\theta[/tex]=97.5 degrees.
Part b tan 48.75=x/2m
x=2.28m
Part c i don't understand?
For part c, we need to consider the refraction of light at the air-water interface. When light travels from air to water, it bends towards the normal (the imaginary line perpendicular to the surface of the water). This means that the fisherman standing on the bank will appear to be at a shallower angle from the fish's perspective.
To calculate the angle at which the fisherman appears to the fish, we can use Snell's law:
n1sin\theta1 = n2sin\theta2
Where n1 is the refractive index of air (1.0), n2 is the refractive index of water (1.33), \theta1 is the angle of incidence (the angle at which light from the fisherman enters the water), and \theta2 is the angle of refraction (the angle at which light bends towards the normal inside the water).
Since we know that the fish is 6m from the bank, we can use basic trigonometry to calculate the angle of incidence:
tan\theta1 = 6m/x
Where x is the distance from the fisherman to the point where the light enters the water. Solving for x, we get x = 6m/tan\theta1.
Substituting this into Snell's law, we get:
1.0 * sin(\theta1) = 1.33 * sin(\theta2)
Solving for \theta2, we get:
\theta2 = arcsin(1.0/1.33 * sin(\theta1))
Plugging in the value we calculated for \theta1, we get:
\theta2 = arcsin(1.0/1.33 * tan^-1(6m/x))
Now, to determine if the fish can see the fisherman and vice versa, we need to compare the angles at which they see each other. If the angle at which the fish sees the fisherman is smaller than the angle at which the fisherman sees the fish, then the fish will be able to see the fisherman but the fisherman will not be able to see the fish. If the opposite is true, then the fisherman will be able to see the fish but the fish will not be able to see the fisherman.
So, we need to compare the angle we calculated for \theta2 to the angle we calculated for \
FAQ: Snell's Window fisherman problem TIRF
1) What is Snell's Window fisherman problem TIRF?
Snell's Window fisherman problem TIRF is a scientific phenomenon that occurs when a fisherman looks at an object underwater at a certain angle and sees it as if it were on the surface of the water. This is due to the principles of refraction and total internal reflection.
2) How does Snell's Window fisherman problem TIRF work?
Snell's Window fisherman problem TIRF works by light rays bending as they pass through the water and then reflecting off the surface at a specific angle. This creates an illusion of the object being on the surface of the water, rather than underwater.
3) What is the significance of Snell's Window fisherman problem TIRF?
Snell's Window fisherman problem TIRF has both scientific and practical significance. It helps us understand the behavior of light in different mediums, and it can also be used by fishermen to spot objects or fish underwater that would normally be difficult to see from the surface.
4) Can Snell's Window fisherman problem TIRF be observed in other environments besides water?
Yes, Snell's Window fisherman problem TIRF can also be observed in other mediums such as air and glass. However, it is most commonly observed in water due to its high refractive index.
5) How can Snell's Window fisherman problem TIRF be calculated or predicted?
Snell's Window fisherman problem TIRF can be calculated using Snell's Law, which relates the angle of incidence and angle of refraction to the refractive indices of the two mediums. This can help predict the angle at which an object will appear to be on the surface of the water.
