So I get the same answer as the book except for a constant term.
In summary, the conversation is about solving a trigonometric integral and finding the correct answer. The person initially makes a mistake in their substitution, but after some help, they arrive at the correct solution. However, their answer is different from the one in the book, but after further simplification, they realize that they both lead to the same result.
paulmdrdo1
385
i'm kind of unsure of my solution here please check.
$\displaystyle\int \sin^3x\cos^3x= \int(\sin x \cos x)^3 =\int(\frac{1}{2}\sin2x)^3=\frac{1}{8}\int \sin^3 2x dx$
$\displaystyle u=2x$; $\displaystyle du=2dx$; $\displaystyle dx=\frac{1}{2}du$
$\displaystyle \frac{1}{8}\int \frac{1}{2}\sin^3 u du= \frac{1}{16}\int \sin^3 udu=\frac{1}{16}\int \sin^2 u(\sin u)du=\frac{1}{16}\int \sin u(1-\cos^2 u)du$
$\displaystyle z=\cos u$; $\displaystyle dz=-\sin u du$; $\displaystyle du=-\frac{dz}{\sin u}$$\displaystyle-\frac{1}{16}\int \sin u(1-z^2)\frac{dz}{\sin u}=-\frac{1}{16}\int (1-z^2)dz$
$\displaystyle-\frac{1}{16}\left(z-\frac{z^3}{3}\right)+C=-\frac{1}{16}z+\frac{1}{48}z^3+C$= $\displaystyle -\frac{1}{16}\cos 2x+\frac{1}{48}\cos^3 2x+C$ ---> this is my answer
but in my book the answer is different $\displaystyle \frac{1}{4}\sin^4 x-\frac{1}{6}\sin^6 x+C$
please tell me where i was wrong.
Re: trigonometric integrals
Well the first thing that sticks out is that if you make the substitution [tex]\displaystyle \begin{align*} z = \cos{(u)} \end{align*}[/tex] then [tex]\displaystyle \begin{align*} dz = -\sin{(u)}\,du \end{align*}[/tex]...
i've changed my answer to this $\displaystyle -\frac{1}{16}\cos 2x+\frac{1}{48}\cos^3 2x+C$
can you help me with the other mistakes.
I would rewrite the integral as:
\(\displaystyle \int \sin^3(x)\left(1-\sin^2(x) \right)\cos(x)\,dx=\int\sin^3(x)\cos(x)\,dx-\int\sin^5(x)\cos(x)\,dx\)
and then for both integrals use the substitution:
\(\displaystyle u=\sin(x)\,\therefore\,du=\cos(x)\,dx\)
I get the same result following your work so I feel the book is a different version of yours.
$\cos(2x) = 1-2\sin^2(x)$
$\displaystyle -\frac{1}{16}(1-2\sin^2(x))+\frac{1}{48}(1-2\sin^2(x))^3+C$
$\displaystyle -\frac{1}{16} + \frac{1}{8}\sin^2(x)) +\frac{1}{48} ( 1 - 6\sin^2(x) + 12\sin^4(x) - 8\sin^6(x))+ C$
$\displaystyle -\frac{1}{16} + \frac{1}{8}\sin^2(x)) +\frac{1}{48} - \frac{1}{8}\sin^2(x) + \frac{1}{4}\sin^4(x) - \frac{1}{6}\sin^6(x)+ C$
$\displaystyle -\frac{1}{16} +\frac{1}{48} + \frac{1}{4}\sin^4(x) - \frac{1}{6}\sin^6(x)+ C$
$\displaystyle -\frac{1}{16} +\frac{1}{48} + \frac{1}{4}\sin^4(x) - \frac{1}{6}\sin^6(x)+ C' \text{ where } C' = C + \frac{1}{16} - \frac{1}{48}$
$\displaystyle \frac{1}{4}\sin^4(x) - \frac{1}{6}\sin^6(x)+ C'$
FAQ: So I get the same answer as the book except for a constant term.
What are trigonometric integrals?
Trigonometric integrals are integrals that involve trigonometric functions, such as sine, cosine, tangent, and their inverses. These functions are used to describe the relationships between the sides and angles of a triangle.
Why are trigonometric integrals important?
Trigonometric integrals are important in various fields of science, including physics, engineering, and mathematics. They are used to solve problems involving periodic phenomena, such as oscillations and waves.
How do I solve a trigonometric integral?
To solve a trigonometric integral, you can use techniques such as trigonometric identities, substitution, and integration by parts. It is important to have a good understanding of trigonometric functions and their properties in order to solve these integrals.
What are some common trigonometric integrals?
Some common trigonometric integrals include integrals of the form ∫sin^n(x)cos^m(x)dx, ∫tan^n(x)dx, and ∫sec^n(x)dx. These integrals can be solved using various techniques, such as the double angle formula and trigonometric identities.
What are the applications of trigonometric integrals?
Trigonometric integrals have many practical applications, such as in the fields of physics, engineering, and astronomy. They are used to solve problems involving periodic phenomena, such as calculating the velocity of a swinging pendulum or the displacement of a vibrating string.
