So the exact value of Cos(-pi/3) is 1/2.
  • MHB
  • Thread starter riri
  • Tags
    Value
In summary, the value of $\cos(-\pi/3)$ is equal to the y-value of $-\frac{1}{2}$ when drawn on a unit circle, or simply equal to $\frac{1}{2}$ by using the even property of cosine.
riri
28
Hello!
Simple as it sounds, I would greatly appreciate help on finding the exact value of Cos(\frac{-\pi}{3}
If I need to find a negative value of Cos, does it become the inverse?
So, since if I draw on unit circle, I get (\frac{\sqrt{3}}{2}, \frac{-1}{2}), would the value of Cos(-pi/3) = the y-value of -1/2?
Thank you!
Mathematics news on Phys.org
riri said:
Hello!
Thank you!
No. you should get $(\frac{1}{2}, \frac{-\sqrt{3}}{2})$ and you should take the x value as $\cos = \frac{x}{hypotenuse }$ and value of cos is x as hypotenuse is 1
riri said:
Hello!
Thank you!
You could also use the fact that cosine is an even function, that is $\cos(-\theta)=\cos(\theta)$ to write:
\(\displaystyle \cos\left(-\frac{\pi}{3}\right)=\cos\left(\frac{\pi}{3}\right)=\frac{1}{2}\)
FAQ: So the exact value of Cos(-pi/3) is 1/2.
What is the exact value of Cos(-pi/3)?
The exact value of Cos(-pi/3) is 1/2.
How do you calculate the exact value of Cos(-pi/3)?
To calculate the exact value of Cos(-pi/3), you can use the unit circle or a calculator. Alternatively, you can use the cosine function formula, cos(x) = adjacent side/hypotenuse, in a right triangle with angle -pi/3.
Why is the exact value of Cos(-pi/3) important in mathematics?
The exact value of Cos(-pi/3) is important in mathematics because it is a special value that is commonly used in trigonometric functions and identities. It also helps in solving mathematical problems and equations involving angles and ratios.
What is the difference between the exact value and approximate value of Cos(-pi/3)?
The exact value of Cos(-pi/3) is the precise value of the cosine function at an angle of -pi/3, which is 1/2. The approximate value, on the other hand, is an estimate of the exact value, usually rounded to a certain number of decimal places. For Cos(-pi/3), the approximate value is 0.5.
Can the exact value of Cos(-pi/3) be simplified further?
No, the exact value of Cos(-pi/3) cannot be simplified further. It is already in its simplest form, 1/2, and cannot be reduced to a simpler fraction or expressed in a simpler form.
