So what exactly is entanglement?
  • Thread starter daveyrocket
  • Tags
    Entanglement
In summary: The thing that's bugging me is that any Slater determinant is automatically going to be a non-product state. Which means any system that you invent that has at least two electrons or any other set of identical particles is going to be entangled. So I could write a Hamiltonian like H = -\frac{e^2}{r_1} + -\frac{e^2}{r_2-R}, ie. two hydrogen atoms separated by a vector R which could be anywhere from the Bohr radius to the size of the galaxy. The solution is something like the state I wrote above. It doesn't matter what the separation is, as soon as I write down the Slater determinant for my wavefunction I
daveyrocket
164
It seems to me that when we talk about entanglement, in a first-quantized kind of language we would say that the wavefunction is not separable into products of single particle wavefunctions, ie. [itex]\psi(x_1,x_2) \neq \psi_1(x_1) \psi_2(x_2)[/itex].
This would mean that any state with identical particles would be entangled... say for 1/2-spin Fermions in a singlet state, [itex]\psi_{1,2} = \tfrac{1}{\sqrt(2)} \left[ \uparrow\downarrow - \downarrow \uparrow \right][/itex] is an entangled state. So for any state, you write out a Slater determinant and you get an entangled state, right? Is this a kind of "trivial" entanglement which is not very interesting, compared to the stuff you read about in pop science articles about quantum entanglement? Is there some way to take an entangled state and measure how interesting it will be?
"Interesting" is subjective. The state you mention is hardly trivial though: it is the entangled state used in the Bell inequality. It can also be used for quantum teleportation, non-local measurements, and pretty much all the "interesting" things we do with entanglement! The non-separability definition you mention is the only one there is: for ##|\psi\rangle## in ##H_1 \times H_2##, ##|\psi\rangle## is a product state if ##\exists |\psi_1\rangle \in H_1## and ##\exists |\psi_2\rangle \in H_2## such that ##|\psi\rangle = |\psi_1\rangle \otimes |\psi_2\rangle##; otherwise, it is entangled. There's no further categorization of "trivially" entangled.
I don't know if this something like what you are looking for, but there is a notion of degrees of entanglement, which corresponds to how much entropy the individual components of the state have. The state you mentioned is known as "maximally entangled", since either of the two fermions (taken individually) has a state described by a reduced density matrix that is a multiple of the unit matrix. Thus, a spin measurement along any axis of one the fermions will yield spin up or spin down with 50% probability each. Up to an overall phase, there are four unique maximally entangled states of two two-level systems (qubits): they are the Bell states, and in my opinion they are the most interesting two-particle entangled states. They show up very often in quantum information theory.
Well, I know interesting is subjective, and I was being a little facetious there, but that's because I'm missing a way to describe entanglement that is not very interesting.
The thing that's bugging me is that any Slater determinant is automatically going to be a non-product state. Which means any system that you invent that has at least two electrons or any other set of identical particles is going to be entangled. So I could write a Hamiltonian like [itex]H = -\frac{e^2}{r_1} + -\frac{e^2}{r_2-R}[/itex], ie. two hydrogen atoms separated by a vector R which could be anywhere from the Bohr radius to the size of the galaxy. The solution is something like the state I wrote above. It doesn't matter what the separation is, as soon as I write down the Slater determinant for my wavefunction I get an entangled state.
But that's weird, because if R is taken as very large, I might as well approximate these as two separate hydrogen atoms. The history of these two atoms is irrelevant. It doesn't matter if they have always been at opposite edges of the galaxy, they're automatically entangled via the symmetrization condition of the wavefunction.
Of course, realistically if two hydrogen atoms are separated by a great distance, even if we stick to the H[itex]_2[/itex] molecule description, any excitation from the singlet state to a triplet state would cost virtually zero energy. So any perturbation that walks by one of the atoms would easily alter the wavefunction. Although, the antisymmetrization requirement would still give an entangled state. But this case, to me, seems like it could be called "maximally boring entanglement," since it's certainly not the type of entanglement that PRL's get written about.
"Weird" doesn't equal "False", however. If you push your math here, what does it tell you - as in, "You"?
From the imagined dialogue between Bell and Jauch in _Age of Entanglement_:
"Bell had a faraway look on his face and he was nodding slightly. "Terrible things happen in the Bohm theory," he said amusingly. "The trajectories assigned to the elementary particles instantaneously change when anyone moves a magnet anywhere in the universe." "
Well, so what?!??
Keep pushing, daveyrocket. Keep pushing.
CW
I'm not sure what you mean with that question. I thought I had described what it was telling me.
I'm very intrigued with your analysis. Just a little encouragement. I think you're onto something, something that's the opposite of boring.
[[Edit: I'm removing some side issue speculations.]]
To me, your post is very good.
CW
In the calculations of ##\psi## functions for atoms and molecules, this is called by the boring term correlation - the electrons do not move independently. The electrons never get far from each other, so it is hard to check out these correlations directly. Perhaps that is why they are not so "interesting". They are however considered daily in most quantum-chemical calculations.
Perhaps the correlations of two state models are more "interesting" because they are mathematically simpler and can be used to model weak radiation and do some interesting correlation experiments with it.
I guess it sort of bothers me that entanglement is such a buzzword, but it's a basic property of any multi-particle system.
Related to So what exactly is entanglement?
1. What is entanglement?
Entanglement is a phenomenon in quantum physics where two particles become connected in such a way that the state of one particle affects the state of the other, no matter how far apart they are. This means that even if the particles are separated by a large distance, they will still act as if they are connected and can influence each other's behavior.
2. How does entanglement occur?
Entanglement occurs when two particles interact with each other in such a way that their quantum states become dependent on each other. This can happen through processes such as collision, decay, or through the use of quantum entanglement devices.
3. What are the implications of entanglement?
The implications of entanglement are vast and have the potential to revolutionize fields such as communication, computing, and cryptography. Entanglement allows for the transfer of information instantaneously, which could lead to the development of super-fast computers and secure communication networks.
4. Can entanglement be observed in real life?
Yes, entanglement has been observed and demonstrated in various experiments. One famous example is the EPR (Einstein-Podolsky-Rosen) experiment, where two entangled particles were separated by a large distance and still showed correlated behavior. Entanglement is also a crucial aspect of many quantum technologies, such as quantum teleportation and quantum cryptography.
5. How does entanglement relate to the concept of superposition?
Superposition is a fundamental principle of quantum mechanics, where a particle can exist in multiple states at the same time. Entanglement is related to superposition because when two particles become entangled, their quantum states become "superposed" and are no longer independent of each other. This means that measuring the state of one particle will affect the state of the other, breaking the superposition and revealing the state of both particles.
  • Quantum Physics
  • Quantum Interpretations and Foundations
