Sodium hydride from sodium and hydrochloric acid
In summary: Otherwise, you'll just form sodium chloride.In summary, sodium can react with hydrochloric acid to form sodium chloride and free hydrogen. It can also react with hydrochloric salts to form sodium hydride and sodium chloride. Sodium hydride can be formed in good proportion by passing hydrochloride gas into liquid sodium. However, it is important to note that the reaction must be done without the presence of oxygen in order to produce sodium hydride. If oxygen is present, the reaction will instead form sodium chloride and sodium oxide or sodium hydroxide.
chloe100
i know that sodium react with hydrochloric acid to form sodium chloride and(according to what i readed) free hydrogen. but i also readed in wikipedia that sodium hydride is made by the direct reaction of liquid sodium with hydrogen. so sodium hydride can be formed in good proportion by passing hydrochloride gas into liquid sodium?, and what about hydrochloride salts? sodium can also react with the hydrochloride to form sodium hydride and sodium chloride?.
and another question, dose sodium hydride is pyrophoric? dose sodium hydride can be extracted from that reaction without inert atmosphere?
Chemistry news on Phys.org
chloe100 said:
sodium hydride can be formed in good proportion by passing hydrochloride gas into liquid sodium?/QUOTE]
Same question: IF the number of moles of sodium exceeds the number of moles of HCl being reacted, yes.
so it reacts with both HCl gas and salts?. and what about the reaction itself? it will produce enough heat to burn the sodium hydride? i readed in wiki that this substance is extremely flammable.
chloe100 said:
salts?
Only if the free energy of formation of NaCl is greater than that of the chloride salt being reacted.
Which reaction? The NaH formation?
If you're forming NaH, the reaction forming it will not "burn" it. If you do this in the presence of oxygen, all you form is Na2O and water.
i meant to the hydrochloride salt, does sodium metal can react with some hydrochloride salts to form NaH?. if so it can work with the presence of oxygen?
"Hydrochloride salt" is an archaic (outdated, obsolete, useless, meaningless) term for describing chloride salts formed with organic bases, usually containing nitrogen, but there are others.
No.
No.
No.
so basicaly in the presence of oxygen sodium metal will react with this kind of salt(just called "chloride"?) to form sodium chloride and sodium oxide and water(sodium hydroxide at the end right?) and without oxygen it will form sodium chloride and sodium hydride?.
Yes, so long as there is an excess of sodium metal beyond what's consumed forming the chloride.
Related to Sodium hydride from sodium and hydrochloric acid
1. What is sodium hydride?
Sodium hydride is a chemical compound with the molecular formula NaH. It is a white, odorless solid that is highly reactive with water and acids.
2. How is sodium hydride made from sodium and hydrochloric acid?
Sodium hydride is formed when sodium metal reacts with hydrochloric acid. The reaction produces hydrogen gas and sodium hydride as the main product.
3. What are the properties of sodium hydride?
Sodium hydride is a strong reducing agent and can react violently with water and acids. It has a high melting point of over 800°C and is insoluble in most solvents.
4. What are the common uses of sodium hydride?
Sodium hydride is primarily used as a reducing agent in organic synthesis and in the production of other chemicals. It is also used in the manufacturing of batteries and as a desiccant.
5. Is sodium hydride dangerous?
Sodium hydride is a highly reactive and potentially dangerous chemical. It should be handled with extreme caution and proper protective equipment should be worn. It can cause burns and irritation if it comes into contact with the skin or eyes, and can release flammable hydrogen gas when in contact with water or acids.
